00 Camry steering wheel vibrates - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2004, 03:26 PM   #1 (permalink)
View solidg's Photo Gallery
My steering wheel vibrates when I go over 60 mph. I checked the air pressure in my tires and there fine. Any ideas on what the problem could be?
solidg is offline   Reply With Quote
Old 03-04-2004, 03:42 PM   #2 (permalink)
View BootMachine's Photo Gallery
- bent rim
- balancer weight fell off
- tie rod end worn
- bad bushings
- worn bearing
Drive Fast & Learn Fast, To Drive Slow!...Drive Slow & Learn Slow...That You Can Drive Fast!
BootMachine is offline   Reply With Quote
Old 07-06-2004, 09:33 AM   #3 (permalink)
Pimpin' In Paradise.
View cheeba's Photo Gallery
my 2000 camry ce does the same thing when it hits 60. did anybody find out a solution?
I've paid for your sins, now gimme my change!
cheeba is offline   Reply With Quote
Old 07-06-2004, 11:17 AM   #4 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
Originally posted by BootMachine
- bent rim
- tie rod end worn
- bad bushings
- worn bearing
^^ What he said...people just get your tires rotated and balanced on a regular intervals, and the tire shop will advise you accordingly what needs to be replaced (if any).
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 07-06-2004, 02:28 PM   #5 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
ditto
Also some tires go out of round, that was my problem.
Belt seperation.
old faithful
amerikim is offline   Reply With Quote
Old 07-06-2004, 02:50 PM   #6 (permalink)
View 93camrytexas's Photo Gallery
it could also be a broken belt in the tire itself
93camrytexas is offline   Reply With Quote
Old 07-06-2004, 03:43 PM   #7 (permalink)
So.Cal 99 camry
BILLSHEA99's Avatar
View BILLSHEA99's Photo Gallery
alignment? maybe...
Team 13Devils CF CAMRY
BILLSHEA99 is offline   Reply With Quote
Old 07-06-2004, 04:38 PM   #8 (permalink)
View joel_musicman's Photo Gallery
sometimes just the tire wear.
My '99 didn't start doing that UNTIL I rotated the tires.
-Joel
My new baby! 2007 Toyota Camry SE V6 - Super White
'99 Camry LE, Reverse Glow Gauges, Strut Brace, & Infinity Basslink
joel_musicman is offline   Reply With Quote
Old 07-06-2004, 06:11 PM   #9 (permalink)
Ford Powered
View initial-T's Photo Gallery
our '01 does that at different speeds..but then again it's never been rotated to my knowledge.
- 1999 Ford Mustang LX 5-spd
- 1993 Toyota Camry Wagon LE SOLD
initial-T is offline   Reply With Quote
Old 07-06-2004, 07:48 PM   #10 (permalink)
View MYCARcamry's Photo Gallery
my 92 camry use to do that same exact thing at right about 60 mph my father went out and bought something and he put it in the gas tank i forgot the name of it but the problem was the fuel injector it was clogged after that the car was running sweeter than sugar water!!
MYCARcamry is offline   Reply With Quote
Old 07-06-2004, 08:01 PM   #11 (permalink)
A SNAIL POWERS MY CAMRY!
View 5Sfte's Photo Gallery
- bent rim
- tie rod end worn
- bad bushings
- worn bearing
Don't forget motor mounts.
88 Camry 4CYL- Stolen, recovered, sold.
94 Camry 4CYL- Jacked up tranny, sold.
92 Camry 4CYL 4DR 5SPD- Ehh, it runs.
96 Camry 4CYL 2DR 5SPD- TURBO, 10PSI
http://www.myspace.com/camry5sgte
TN Map... Add yourself NOW!!!
5Sfte is offline   Reply With Quote
Old 07-07-2004, 09:06 AM   #12 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
Motor mounts would make the engine/chassy shake/vibrate at idle not at highway speeeds unless i'm missing something.....
Old 07-07-2004, 09:13 AM   #13 (permalink)
View allison's Photo Gallery
Originally posted by BILLSHEA99
alignment? maybe...
alignment won't make the wheel vibrate. the car would be pulling if it was in need of alignment. it's what ^ they said about either out of balance tire(s), bent rim, balance weight may have fallen off, broken belt, etc.
allison is offline   Reply With Quote
