Originally posted by terrynham
I know the point of an aftermarket cap is for a higher pressure
but I was just concerned whether putting a higher pressure cap (1.3kpa) on a cooling system made for a lower pressure (0.9kpa) will affect the system in the long term?
No, I don't think you get it. You are only improving your cooling system by adding the cap so that it can handle more pressure.
Your question would be similar of asking if there is any drawback to adding Z rated performance tires on a car that wasn't designed to go over 100mph.
Chances are you won't need them, but it can't hurt to have higher quality parts.
