Front end vibration
I have a 2000 Camry V6 with 169K on it. I have never had any trouble with it until now. Recently the front end started vibrating. I took the car to Mr.Tire and they determined that one of my tires had a bad belt in it and replaced the tire. this did NOT help. the vibration starts around 30/40 mph and gets worse as you drive. But, if I pull over and stop, then drive again it sometimes does NOT vibrate at all. also, when i slow down the car rocks forward and backward. i am not driving unitl i can determine the problem.
I'm thinking i have a bad CV joint/axle. when the CV joint is at a certain point it's fine, then when it's off that point i get the vibration. at times it feels like i have two flat front tires.
any ideas??
thanks
Mel
