Man, it's going to be a lot of work. Since yours is a 94, the 1MZ will fit. You can ask Zoni for the wiring. He has done the swap with a 94 V6 engine into a 94 chassis. The wiring is the hardest part. Everything else should bolt right in. In my case, I used a 98 1MZ, and more custom wiring had to be done since I was using a 92 chassis. There are suttle differences, that should not effect anything. If you use the 94 ECU, you will only get 185HP, but if you use the 97+ you can get 194hp. THis is just the start. IF you want more info, try a search, and it should come up with more info. The tranny for a I4 may not work cause of gearing, but I may be wrong. Good luck.
