Install Keyless - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-20-2010, 05:29 PM   #1 (permalink)
Kaddo's Avatar
View Kaddo's Photo Gallery
Canada Install Keyless
My Camry has central locking system, but I'm missing the keyless entry.
I purchased a kit and would like to install it (done that once successfully, on a different car).
This Camry having its controls on the driver's door, I figure I could place there my keyless entry receiver,
conveniently tapping its connections to the existing control unit, once I locate them.
A number of wires are going to/coming from that control unit. I will only need 4:
+12V(constant), Ground, Lock Pulse and Unlock Pulse.
Openning the control unit, I could see on the PC board some terminals which seem waiting for such addition (suggestive markings).
I also unplugged the connector and using my multimeter, searched for the +12V(constant), but could not find it.
Is it because of the unplugged connector?
It would be of great help if I knew the color coding of all those wires.
Thanks for your attention.
'97 Camry LE, 2.2L, 5-Spd.
Kaddo is offline   Reply With Quote
Old 01-24-2010, 10:48 AM   #2 (permalink)
View JerryR's Photo Gallery
Looking at the schematic I don't think there is +12v constant in the door.
when I installed an alarm system(including keyless entry) in that car, I done all my connections at what toyota calls an "Integration relay". the +12v, Gnd, Lock and Unlock(and more) are available there.
the unit is mounted(if i remember right) behind the fuse panel.
yjryba<at>yahoo<dot>com
To contact me via Email
Replace Text within< > with proper symbols.
JerryR is offline   Reply With Quote
