I have a 3VZFE cam roundin 160,00 I know this question has been asked but never really answered. How hard and expensive would it be to rebuild the beast, or if anything has anyone ever gone thru and changed all there seals and gaskets, thats my biggest beef with the motor right now is its startin to leak, and wouldnt ya know it drips right down on the exhaust manifold YEAHH for smellin like oil. Thanks
i dunno how much it would cost to rebuild..if ur not doing it urself labor will be a bitch
my crankshaft blew out on me a while back..got an engine from a rear-end accident 80k miles
$2800 plus 1 year warranty on engine
maybe cheaper to swap?
Gen-3 Coupe '95 1MZ-FE
Custom Ram Intake w/K&N Filter
H & R Springs, Strut Bar,
Denso Plugs, Crappy 6 Spoke 16" Nissan rims w/kumho rubber (i got um for free ok?)
TRD Supercharger, Custom exhaust coming soon..maybe..hopefully..someone got some extra loot?
got mine rebuilt by the toyota service dept... it was about $2000 for all top end gaskets to be replaced. my 3vz blew a head gasket at 162K, and i didnt have the garage or the time (school) to rebuild it. runs like new now though!
probably would be easier to swap- but its impossible to find a brand new 3vz. so the only way to get a like-new 3vz is by a rebuild...
So what all would it intale to rebuild this beast, maybe I dont need to i dunno, I at least got to get that bitch to stop leakin oil, i think its commin ou the real valve cover seal, thatrs the one drippin on the manifold anyway, any of you ever replaced that, and also its leakin out of the cam seals. those little circle seals on the drivers side of our motor, i beleive one is around the distributer, you know about any of this.
don know what to tell u 'bout that...hope u have luck with it bro...suxs to see another cam on the sidelines
Originally posted by camcar I at least got to get that bitch to stop leakin oil, i think its commin ou the real valve cover seal, thatrs the one drippin on the manifold anyway, any of you ever replaced that
If the valve cover is leaking its just a matter of removing it, replacing the gasket, and bolting it back on.
The cam seals are on the left side of the motor behind the camgear / cam pulley.
Theres a cap that goes over the top of the distributor. It bolts onto the head, so you can't get to it without removing the valve cover. It could be leaking from there or around the distributor shaft (theres a o-ring on the distributor).
I did a 5sfe everything new pistons belts hose oil pump ect 1500 500 machine shop bore grind crank press pistons ect 550 I think for a kit from rpmrons. Great guy graet service did it all in driveway and every seal known to man and then some 8000 mi later no problms
