Rear License Plate Lights not Working? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-09-2010, 01:37 PM   #1 (permalink)
View MARK2's Photo Gallery
I replaced the two license plate bulbs on my 97 Camry and they still don't work. Anyone have any ideas on any other areas I should check? Maybe a fuse or other problem areas that could cause this. I was pulled over and given a ticket the other night for these being burnt out.
Thanks!
MARK2 is offline   Reply With Quote
Old 02-09-2010, 02:52 PM   #2 (permalink)
340,000 miles+......
sk8ersublime's Avatar
View sk8ersublime's Photo Gallery
check the socket for corrosion, try cleaning it out, check the wires, turn your lights on whne you check in case you didn't :P
http://www.cardomain.com/ride/2915998
340,000+
sk8ersublime is offline   Reply With Quote
Old 02-09-2010, 08:56 PM   #3 (permalink)
Gameroom cash: $304355
If there is no corrosion on the sockets, then check the loom of wires inside the trunk by the driver's side trunk hinge. Those wires can frey and break from all the flexing they are exposed to as the trunk is constantly opened and closed over the years. Open up that loom of wires and check for freyed or broken wires. Repair what you find.
Mike
