Oil leak probelm...Help? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-10-2004, 06:01 PM   #1 (permalink)
undrcroft's Avatar
View undrcroft's Photo Gallery
Theres seems to be a small oil leak around the bottom of the transmission. The bottom side of the transmission as it extends bellow where it meets with block, has a black metal plate on the side of the transmission right beside the oil pan. Oil seems to be coming out from in between the bottom of the plate and the tranny. Is it possible that oil is comming out there, or is it coming from somewhere else. I know its oil. How do i fix this? whats under the plate?
Drives: '03 Tacoma 4cyl 2X4
undrcroft is offline   Reply With Quote
Old 03-10-2004, 09:09 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: Oil leak probelm...Help?
Rear main seal is leaking.
Remove tranny, flexplate, and replace rear main seal.
Its a access plate for the flexplate and torque converter.
"Skoolin' the unlearned!"
Old 03-11-2004, 06:36 PM   #3 (permalink)
undrcroft's Avatar
This is going to get porogressivily worse right?
Old 03-11-2004, 06:50 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
Yes.
