96 Camry Motor Mounts Or?
Car vibrates through the steering wheel with engine in gear at idle. Replaced front motor mount and T-bone. Vibration actually seems a bid more intense now.
Should I also have replaced the rear motor mount? How do you tell? If so how much time does it require in a shop?
Read other posts. Someone mentioned he replaced engine control moving rod. Is there a test for this and again how long should a shop take to replace it?
Is there anything else I should be considering?
Help appreciated.
Life is good,
Bill
