O/D Off light keeps blinking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-12-2004, 10:33 AM   #1 (permalink)
Post Hoc Ergo Propter Hoc
Bishop13's Avatar
View Bishop13's Photo Gallery
What does that mean? It blinks even tho the O/D is on...wierd...
EDIT: Oh yeah, its a Gen3 I4
Capitalization is the difference between helping your uncle Jack off a horse, and helping your uncle jack off a horse
1997 Toyota Camry LE / 2001 Land Rover Discovery II / 2006 Audi A4
http://www.flickr.com/photos/henryenriquez/
Bishop13 is offline   Reply With Quote
Old 03-12-2004, 11:22 AM   #2 (permalink)
Bring it !
View WickedGen3's Photo Gallery
not sure but i've seen some posts says that your tranny has some problems.. thats why i've read but i am not sure better let some experts handle it
WickedGen3 is offline   Reply With Quote
Old 03-12-2004, 11:43 AM   #3 (permalink)
View alflash's Photo Gallery
Hi,
Take a look http://forum.toyotanation.com/showth...511&forumid=15
HTH,
J2008: Beginning 2002, manufacturers shall make available at a fair and reasonable price,all 2002 and newer model year vehicle emission-related diagnosis and repair information provided to the manufacturer’s franchised dealers.Within 30 days of its availability to franchised dealers.
alflash is offline   Reply With Quote
Old 03-22-2004, 12:50 PM   #4 (permalink)
Bishop13's Avatar
Alright, so it was a code "63 - No. 2 Shift Solenoid short-circuit". I checked out the harness and found the connector to be dislodged, so i cleaned and reconnected it, but I'm still getting the same error code and symptoms (not shifting to 3rd gear). Anyone know 'bout how much it would be to replace/repair the solenoid? Plus, where the heck is it?!? I looked it up on the Haynes manual and it seems that its behind the fender liner on the driver's side, but I'm not sure...
Old 03-23-2004, 12:16 PM   #5 (permalink)
Hi,
Please, let us (and me ;-) know the type A/T on yours car.
BR,
Old 03-23-2004, 02:45 PM   #6 (permalink)
Bishop13's Avatar
Originally posted by alflash
Hi,
BR,
Ooops. Its an crap-matic on a 93 I4 :-D
Old 03-23-2004, 11:17 PM   #7 (permalink)
Hello,
Dear Sir,
I'm sorry, but sometimes I don't understand what you mean in your message,
Could you please tell me that in other words?
Thanks,
Best Regards,
Old 03-24-2004, 01:08 PM   #8 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
read this, it will give you some insight on the tranny shifting operations and the solenoids...
http://forum.toyotanation.com/showth...ifts+backwards
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 03-24-2004, 02:01 PM   #9 (permalink)
Quote (example, for A541E):
...The ECT ECU receives information from various input devices
and uses this information to control No. 1 and No. 2 shift solenoids on transmission valve body for transmission shifting and lock-up solenoid for torque converter lock-up...
... ECT ECU OUTPUT DEVICES
No. 1 & 2 Solenoids
The ECT ECU controls transmission shifting by delivering an
output signal to operate proper solenoid. Solenoids are located on transmission valve body. See Fig. N. Solenoids are operated in
accordance with shift lever position. See Fig. N. If a solenoid
malfunctions, fail safe selected gear may result.
NOTE: In some gears, ECT ECU provides a fail-safe system which
will place transmission in designated gear depending on
solenoid failure.
Lock-Up Solenoid
The ECT ECU controls torque converter lock-up by delivering
an output signal to lock-up solenoid. Lock-up solenoid is activated
when shift lever is in "D" position and vehicle is at specified speed. Lock-up solenoid is located on transmission valve body. See Fig.NN (Determining No. 1 & No. 2 Solenoid Operation
Courtesy of Toyota Motor Sales, U.S.A., Inc.)...
...ECT ECU
and uses this information to control No. 1 and 2 solenoids on
CODES "SHIFT SOLENOIDNO. 2 FAULT"
...Remove and inspect operation of solenoids. If solenoids are o'k, inspect valve body...
Circuit Description
The ECT ECU uses signal from direct clutch revolution sensor and vehicle speed sensor to determine actual gear position. ECT ECU
compares actual gear with shift schedule in memory to detect
mechanical trouble of shift solenoid valves and/or valve body. Code is
set if during normal driving gear required by ECT ECU does not match actual gear after 2 trips have been completed...
Old 03-24-2004, 02:09 PM   #10 (permalink)
Bishop13's Avatar
Kewl, thanks Zoni...but you do have the rest of this page:
Old 03-24-2004, 03:19 PM   #11 (permalink)
Robert,
Take a look "Limp-mode" description (if on A/T A541E No.2 solenoid malfunction, "no 3rd" and read SAE DTC P0755) in http://www.alflash.narod.ru/images/541E.gif
Hope this help,
Old 03-24-2004, 03:46 PM   #12 (permalink)
I'm a Mac
zoni's Avatar
i dont get why you need the rest of that page...... lemme know. lemme know exactly what you need. and re read that description of shifting operation. its pretty much what alflash is saying but its a little more understandable from the factory manual...
Dave Zoni
