do you think this antenna would work? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-12-2004, 12:31 PM   #1 (permalink)
View jamesgf's Photo Gallery
Question do you think this antenna would work?
Hi all-
My power antenna just crapped out this week on my 95 LE and no longer goes up and down. Ive decided to put in a fixed mast antenna and was contemplating the s2000 swap.
I ran across this antenna on ebay while looking for the s2000, do you think it would work? (its cheap and im lazy ).
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2466538950
-j
jamesgf is offline   Reply With Quote
Old 03-12-2004, 01:17 PM   #2 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
It doesn't look like it will. You need an antenna base that can handle the contours of the Camry....that one is for a flush mount.
An S2000 antenna only runs $35 Cdn at the dealership....online, they're much cheaper.
Silver Streak is offline   Reply With Quote
Old 03-12-2004, 03:16 PM   #3 (permalink)
View calvic's Photo Gallery
keep looking on e-bay, there is a guy who sells replacement power antennas(not OEM) for not much more than that. If your antenna motor still runs but mast doesn't go up then all you need is a replacement mast, not big bux.
calvic is offline   Reply With Quote
Old 03-12-2004, 04:01 PM   #4 (permalink)
View pasopaul's Photo Gallery
Can you pull the antenna up and disconnect power to the motor. I did this on my 4Runner and the antenna works fine. I had to get into the fender well to disconnect but you might find a breaker or fuse.
paul
pasopaul is offline   Reply With Quote
Old 03-12-2004, 04:11 PM   #5 (permalink)
Silver Streak- I thought the angle that the antenna is mounted on the fender might be a problem with that one.
I can pull the antenna up and it works (as in receives stations) but as i drive around it works its way down and my reception goes bad.
This automatic antenna has given me problems ever since ive had the car (doesnt move in the winter, gets stuck until it finally broke) so i think i will just put in a fixed mast. I found a Metra one (part number AWGM935) that is a universal mast that comes with all of the mounting parts for various cars for around $11. Not sure how cheesy it is for that price though. If it looks crappy i may go the s2000 route.
thanks for the help!
-j
Old 03-12-2004, 06:21 PM   #6 (permalink)
View warlock's Photo Gallery
that ant.goes on the roof,you will have to drill a hole and mount it there and then shave your old one. if you want to do this i have the same one shown i will sell you cheeper than that,like 15 and S/H
94 Scepter 1MZ-FE
< TN Type [R]ice Club>RICERS UNITE!! Join Type R..latest faction of TN!!
.....http://www.toyotanation.com/forum/sh...d.php?t=105457
warlock is offline   Reply With Quote
