Automatic Trans Shifting Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-13-2004, 10:07 PM   #1 (permalink)
View 604-Mico's Photo Gallery
Angry Automatic Trans Shifting Problem
Ok my gen3 v6 has a problem
When I start up my car and try to shift from P to D, the shifter doesnt disengage from P
I know my tranny isnt shot because when i use the shift lock override to drive, the car moves no problem
I've also checked the reverse and it has no problem either
Has anyone come by this problem before?
I hope someone can give me some tips before i bring my car into toyota because those stupid service techs always break something in my car everytime i bring it in!!
Thanks
604-Mico is offline   Reply With Quote
Old 03-13-2004, 10:13 PM   #2 (permalink)
bitch please
DarkMastyr's Avatar
View DarkMastyr's Photo Gallery
Well above the shifter you should see this little black rectangular cover dealy that can be popped off with a flat head screwdriver. I *think* that it's a release switch for the shifter. I haven't tried it before since I've never had to, but I think you just jab the screwdriver in and try shifting. Dunno if it'll work... someone else who's actually fiddled around with it might be able to give you a better idea of what I'm talking about.
1994 Camry 2.2L LE Auto
DarkMastyr is offline   Reply With Quote
Old 03-13-2004, 11:20 PM   #3 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
check your brake lights, if they don't come on then its your brake switch
-Nick
Nick is offline   Reply With Quote
Old 03-14-2004, 01:16 AM   #4 (permalink)
Wow dude you are right on!
Ok so my brake switch is screwed (i assume)
So how much would it cost me to fix that?
Old 03-14-2004, 01:20 AM   #5 (permalink)
Nick's Avatar
salvage yard would be your cheapest bet
but you could get a new one from a dealer
-Nick
Old 03-14-2004, 01:23 AM   #6 (permalink)
Do you know off the top of your head how much it would approximately cost for the part?
Cause i have no clue how muchi should expect for it
Thanx
'94 1mzfe Coupe
2.5" dropzones
Tokico Blues
Gen 3 Camry SE wheels
APS-996 Alarm-Starter Combo
Old 03-14-2004, 01:25 AM   #7 (permalink)
Nick's Avatar
sorry, i don't know, i'll do a quick search, a couple people have had this problem in the last couple months
after a quick search, what i've gathered is 175$ from the dealership, but one guy took it apart and fixed the connection inside
-Nick
Old 03-14-2004, 01:37 AM   #8 (permalink)
cool tnx
you know where to search cause i was lookin and didnt see that
Thanks nick
'94 1mzfe Coupe
2.5" dropzones
Tokico Blues
Old 03-14-2004, 11:40 AM   #9 (permalink)
Corsa!
Galvatron's Avatar
View Galvatron's Photo Gallery
I had this same problem, brake lights didnt come on, and had to use the override to get out of park. It was just the fuse for the brake lights. Might be worth checking.
1992 Tercel DX, 3E-E/3AT
1992 Paseo, 5E-FE/5MT
2007 Suzuki SV650S
http://www.rent-a-tech.org/wordpress
Galvatron is offline   Reply With Quote
Old 03-14-2004, 12:32 PM   #10 (permalink)
just checked my fuses........and you know what.........it was blown
thanx glavatron
saved me a trip to the junkyard and dealer
Old 03-14-2004, 01:02 PM   #11 (permalink)
Nick's Avatar
bah, i would have thought you'd have checked those first
-Nick
Old 03-14-2004, 01:05 PM   #12 (permalink)
I did check them at first but i only did a brief check
Cause my camry is the Canadian version.......which has like 5 different fuse boxes!
But yea......thanx for the quick response guys. Appreciate it
'94 1mzfe Coupe
2.5" dropzones
Tokico Blues
Old 03-14-2004, 02:41 PM   #13 (permalink)
back again? yeah, i am.
Erbe's Avatar
View Erbe's Photo Gallery
u ever drop a screw or somethin down there...cus i did that and it locked a little and then found the screw and pulled it out
back for the very first time.
-pat
Erbe is offline   Reply With Quote
Old 03-14-2004, 04:53 PM   #14 (permalink)
View fe519's Photo Gallery
so have you replaced the fuse and try to see if everything is fine yet?!?!?!
fe519 is offline   Reply With Quote
Old 03-15-2004, 12:31 AM   #15 (permalink)
yep. Replaced it and everything was fine
