I Need Crazy Help Car Died - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2004, 12:01 AM   #1 (permalink)
View Hungrylilb0i's Photo Gallery
look.. dis is what happened.. we were driving around in my car and den some it started needed higher RPM to move.. and den we stopped at a light. and we shifted to first from neutral and it jst wouldnt go.. at all.. we revved more but still nothing.... the reverse works a little.. but none of the gears work now.. the car is dead... wut could be the problem
Hungrylilb0i is offline   Reply With Quote
Old 03-15-2004, 12:10 AM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
1st of all, what year, engine and transmission
-Nick
Nick is offline   Reply With Quote
Old 03-15-2004, 12:49 AM   #3 (permalink)
cam2Xrunner's Avatar
it sounds like its a manual trans car. sounds like the clutch is bad. or the throw-out bearing. prob clutch tho
Old 03-15-2004, 02:06 AM   #4 (permalink)
Nick's Avatar
yeah, really dead clutch or something in that area
-Nick
Old 03-15-2004, 10:44 AM   #5 (permalink)
The Twisted Brother
View Cam-Shaft's Photo Gallery
my first thought ^ I've seen it happen alot of times before...your clutch is dead bro.
Cam-Shaft is offline   Reply With Quote
Old 03-15-2004, 11:58 AM   #6 (permalink)
View luisitol's Photo Gallery
basically what everone is saying is when your car needed more rpms your clutch was slipping drastically ( a tell-tale sign that you need a new clutch) and then it finally went out
So go out and buy a new clutch, you might want to go aftermarket while you're at it and also replace your throw-out bearing, its better to do so than re-use the stock one.
'93 Probe GT - Daily Driver
'93 LE - Show Car - Coming SOON
luisitol is offline   Reply With Quote
Old 03-19-2004, 04:38 PM   #7 (permalink)
thanx guys. bought a new clutch. going to install it next week.. should be an easy install.. rite?
Old 03-19-2004, 04:45 PM   #8 (permalink)
Lives For The Curves
View nort0188's Photo Gallery
If you didn't even know that it was your clutch that had gone bad, I definitely wouldn't tackle the job on your own.
If torque actually won races, wouldn't we all be driving diesels?
nort0188 is offline   Reply With Quote
Old 03-20-2004, 12:28 AM   #9 (permalink)
Nick's Avatar
ditto
hope you got a friend that knows what they're doing...
-Nick
