The only place "self tapping screws" are acceptable is for body work and even then, the factory doesnt use them on many places.
This sounds like a half-assed repair as you already know. Sounds to me like the mechanic might have tightened the pan bolts too tight the first attempt, and squeezed out all the silicone sealant. Thus causing another leak. Then the same guy merely repeated the procedure all over again and perhaps decided that (over)tightening the pan bolts would make it seal (that never works for an oil pan, it makes the leak worse.)
Also the silicone "gasket" should always be replaced with a real gasket plus sealer (permatex brown being my favorite), "silicone gaskets" are nothing more then cost cutting measures by the factory to seal only long enough get you out of warranty (and them out of liability for fixing it.) The mechanic took the easy route of using ONLY silicone sealer, i am guessing - a proper gasket is the solution to the problem.
Since you are having the work done i am guessing a real mechanic would retap all the holes for the next large size bolt. This is the proper repair. But i cant imagine what so-called "mechanic" would mangle all the bolt holes like that, or if it came that way from the factory, why they would do it in such a way.
