Car sometime Stalls on Complete Stop - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2004, 01:02 PM   #1 (permalink)
View Rob9846's Photo Gallery
Question Car sometime Stalls on Complete Stop
I have a 96 Camry. When I come to a complete stop (Toll), after running the car on the highway for about 20min at speeds of 65. The car starts to vibrate hard and try’s to cut off. Sometime it does and sometime it doesn’t. By the way it runs great on the highway. What can be wrong with my car?
Rob9846 is offline   Reply With Quote
Old 03-15-2004, 02:26 PM   #2 (permalink)
View Nico's Photo Gallery
is your car running on 3 cylinders ?
Nico
Nico is offline   Reply With Quote
Old 03-15-2004, 02:42 PM   #3 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700165
iTrader Score: 6 reviews
View EKam's Photo Gallery
^ that means do a compression test.
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 03-15-2004, 02:51 PM   #4 (permalink)
How do you do a compression test?
I'll try and look it up on the web.
Thanks
Old 03-15-2004, 03:02 PM   #5 (permalink)
Thanks
Old 03-15-2004, 03:11 PM   #6 (permalink)
Thanks
Go to any garage and ask for a compression test. It only takes a few minutes and you'll know.
If they are alright (which I hope for you ...) it could be the TPS (Throttle position sensor) or the idle air control valve. (both located on your throttle body. These are damn expensive. Could be many things as well in fact.
Nico
Old 03-15-2004, 07:21 PM   #7 (permalink)
View burchard's Photo Gallery
If your compresion test is ok, check your EGR valve. A 96 car might have some carbon deposits on the shaft of the egr valve and gets stuck open after a hway drive. As Nico said it might be several things, but start checking the simple ones.
burchard is offline   Reply With Quote
