Can't find 92 Camry oil leak - Toyota Nation Forum : Toyota Car and Truck Forums
post #1 of 2 Old 03-21-2010, 01:36 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I replaced all the seals.cam, crank and oil pump. Valve cover gasket and oil cap.
The leak is on the passenger side and appears to be from the top.
If I look from under the car it looks wet below the manifold.
Any ideas?
Thanks
Tappster is offline
post #2 of 2 Old 05-15-2010, 10:02 AM
Quoted: 2 Post(s)
Tappster if you havent found the leak yet, it could be coming out of the distributor seal. usually this seal is just an o ring.
oil leaks can be maddening as you know, there's several ways to find an oil leak, some simple some complicated. the first way is clean the engine like brand new, drive the car and wait. You can also dust suspected leak areas with talcum powder (naturally this only works on a clean engine).
Another way is to buy a dye kit and find the leak that way. Here are some other methods
http://www.tracerline.com/faq.html
AlmightyCamry777 is offline
User Tag List
Linear Mode Linear Mode
Back
