Stuck fuel line nut - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-02-2010, 07:21 PM   #1 (permalink)
View kangadrewy's Photo Gallery
Stuck fuel line nut
Am trying to change fuel pump on 1992 V6 Camry station wagon. . Nut from pump fuel line onto fuel line to engine is solidly stuck. Have used back-up wrench and flare wrench and penetrating oil but to no avail. HeLP me please!
kangadrewy is offline   Reply With Quote
Old 04-03-2010, 01:08 PM   #2 (permalink)
Gameroom cash: $304355
The only thing I can suggest is make sure you are using a good penetrating oil like PB Blaster. Some people use WD 40, which is good for many things, but not really great as a penetrating oil. Spray it several times and let it soak over time. You may even try tapping it lightly after each time you spray it.
Good luck.
Mike
Old 04-03-2010, 07:18 PM   #3 (permalink)
Old 04-03-2010, 07:19 PM   #4 (permalink)
Thank You for your suggestions. Used Loctite Freeze and Release and plumbers wrench. Managed to free both nuts and install new fuel pump - actually, one from the wreckers. Works fine now.
