A couple of days before we took my wife's 93 camry in for regular timing belt change at the local dealer in Santa Fe, we used AC. After the timing belt change, the AC is just blowing hot air and it doesn't feel like the compressor is engaging. I can usually feel if AC is engaged by a little tug at the engine rpm.
Is there anything in the timing belt change that might mess up A/C? I am a little ticked off right now.
it depends.....when they were doing the timing belt, they may have also done hte ac/alternator belt and the power streering belt while they were at it.....
but I'm not sure, but if your alternator is still working, then it might actually be the ac unit cuz they use the same belt...? somebody correct me if I'm wrong
HaHa
"Life is a deep sleep, of which love is the dream..." Ripped...and the girls are loving it.
this happend when i had my corolla s timing belt changed..... they forgot to plug the ac compresor back in... there was a plug just hanging by the compresor and ii plluged it in and it worked.
its just like anyother plug, find ur compresor and see if there is some thing that not pluged in then look around for the plug should be close to it, in my corolla the AC was right up front, i havent looked at my camry to see where it is.
either its the a/c fuse, the plug on the a/c compressor, or the belt is loose, but if the belt is loose then the alternator wouldnt be running either, sooooooo... you would have a low battery and find it hard to start the car in that case... check all 3.
In fact there is nothing in the timing belt change that could have dammaged your a/c system. It is probably just a low charge problem. I would check its pressure
