It's not the IAC...what else? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-18-2004, 08:43 PM   #1 (permalink)
View aypstony's Photo Gallery
My wife has a '95 camy with ~100,000mi. Recently, it developed rough cold start. It will not go into cold fast idle and shakes the whole car. If I don't press the gas pedal, it will stall out. Once the car has been driven a little, it runs perfect.
I have cleaned the IAC. It is working fine---I can feel the vacuum into the hole.
I have changed the coolant temperature sensor---no help.
I was going to change the spark plugs, wires, distributor cap/rotor.
Am I missing anything?? What else could cause the cold fast idle not to kick in?
aypstony is offline   Reply With Quote
Old 03-19-2004, 04:36 AM   #2 (permalink)
View Nico's Photo Gallery
I guess it should be one of the two sensors on the throttle body : TPS or (I don't remember the name of the other one)
Nico
Nico is offline   Reply With Quote
Old 03-19-2004, 09:06 AM   #3 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
did u try adjusting the IAC??....i had a similar problem in my mr2....it turned out to be the intake manifold gasket....had to replace it....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 03-19-2004, 03:40 PM   #4 (permalink)
Thanks for the responses.
Hmmmmm. I will have to look into your suggestions.
I didn't know that you can adjust the IAC.
Old 04-29-2004, 10:05 PM   #5 (permalink)
Add Lightness
View goretro77's Photo Gallery
I think you should replace the IAC but iut's hard to diagnose from internet.
goretro77 is offline   Reply With Quote
Old 04-30-2004, 01:28 AM   #6 (permalink)
View woshiagni's Photo Gallery
Did you remove the IAC to clean it? or did you just spray into the opening and listen for the noise? I've tried the spray method and it only fixed it for 2 days... after I removed it and cleaned it thoroughly, it's been going for about 2 months now.
If you didn't remove it off the throttle body and clean it with a toothbrush... try that first. Could save you $250.
woshiagni is offline   Reply With Quote
Old 04-30-2004, 10:42 PM   #7 (permalink)
View wontonjohnny's Photo Gallery
after you clean it out disconnect the negative side of your battery and leave it disconnected overnight...
i had the same problem and tried cleaning out the IAC, didnt fix the problem, left it for weeks like that.
then when i did my clutch install i disconnected the batt for one night, why that worked i dont know but give it a try.
5 speed 3vzfe - RIP
project F23 CL-T
Custom Y-pipe Project
Custom 1-Piece CAI Project
wontonjohnny is offline   Reply With Quote
Old 05-01-2004, 01:06 AM   #8 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
check fuel pressure, then check intake air flow(try starting the car with the tube open to the outside air)... if that doesnt work out, take it for a tune up...
oh btw, FIRST, get the codes read... if there are any.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
