Radiator fans (oil -> electric) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-19-2004, 06:04 PM   #1 (permalink)
mox
God Machine
mox's Avatar
View mox's Photo Gallery
Anyone replaced his radiator fans to electric fans ?
I am thinking removing the 'power steering fluids powered' fans and put some kind of electric fans.. anyone ever done that ?
mox is offline   Reply With Quote
Old 03-19-2004, 06:22 PM   #2 (permalink)
VVT-i Owns's Avatar
View VVT-i Owns's Photo Gallery
depending on ur car it should already have that
- Vince
VVT-i Owns is offline   Reply With Quote
Old 03-19-2004, 06:26 PM   #3 (permalink)
mox
God Machine
mox's Avatar
I have a '92 camry SE and the radiator fan is powered with the power steering fluid
'92 Camry SE V6 5 Speeds (Pics: 1 | 2 | mox.monchar.com) ('06-now)
Previously owned: '99 Corolla,MT ('99-'01), '97 Camry XLE V6,AT ('01-'02), '92 Camry SE V6,MT ('02-'04), '99 Solara SE V6,MT ('04-'06), '93 Camry LE V6,AT ('06-'07)
Old 03-20-2004, 12:22 AM   #4 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
why? if you're doing it to be different, well then you shoudl be resourceful enough to do it ourself,
otherwise, if it aint broke, don't fuck with it
-Nick
Nick is offline   Reply With Quote
Old 03-20-2004, 08:06 AM   #5 (permalink)
mox
God Machine
mox's Avatar
I don't do it to be different.. It's just that the hoses take some space that I would like to use
Is the gen4 fan electric ?
Old 03-20-2004, 11:52 PM   #6 (permalink)
I am just a newbie!
Tony the Tiger's Avatar
View Tony the Tiger's Photo Gallery
If you convert to electric fan, you will need the basic wiring and switches -- fan, temperature switch, relay, or a master override switch inside cockpit.
You will also need to re-route the hydraulic fan pressure line to bypass the fan and straight to the PS cooler. The pressure line is a banjo fitting, so you will either have to make a new line out of custom plumbing, or chop the banjo fitting, extend the line and route it directly to the cooler. There are many ways of doing it... it doesn't take much work really.
* Goal for 2012 -- 200+ MPH in the Camry
Tony the Tiger is offline   Reply With Quote
Old 03-21-2004, 12:03 AM   #7 (permalink)
VVT-i Owns's Avatar
Ya I think so......
Even our 1993 Corolla was electric.
Anyways if u want to do it, just follow the instructions TOny gave above ^.
- Vince
Old 03-21-2004, 08:17 PM   #8 (permalink)
CTM/ShiftGate CAMRY
racerhex's Avatar
View racerhex's Photo Gallery
ive always been told the 92 SE hydrolic fan is way better then any electric!
3vz-fe w/ all the good stuff
Does My Wiper Offend You? Look Ma no handles!
www.ctmotorsport.com FOR ALL YOUR CAMRY NEEDS
http://members.cardomain.com/racerhex<----CHECK ME OUT...UPDATED!!!!
racerhex is offline   Reply With Quote
Old 03-21-2004, 09:04 PM   #9 (permalink)
I am just a newbie!
Yeah, that's true... the stock hydraulic fan is probably stronger than most electric units out there. Stock fan measures 18" in diameter and pushes a LOT of air. It barely robs any engine power (lesser than the added load to the alternator from an electric fan) because it takes pressure from the power steering which is being driven all the time anyway.
I took mine out because I am running a 3" aluminum rad and I have no room to fit the stock hydraulic anymore.
Old 03-21-2004, 09:24 PM   #10 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
its a LOT of wiring that is near impossible to get the swap done right... i got an engine and ecu and wiring harness from a 94 camry with 1mz and hydro fan. Let me tell you, i wont even try to do that wiring...
i had to wire individual pins on the ecu for my swap, among other things... so i am very good with wiring... and i wont try...
i plan to use an electric fan with a switch setup... just switch it on when i need it, and keep it off if i dont need it.
probably run the switch off of a relay triggered by the ON position of the ignition switch, so when the car is off there is no way i can leave the fan on...
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 03-22-2004, 11:56 AM   #11 (permalink)
5spd V6 ClrTail's Avatar
View 5spd V6 ClrTail's Photo Gallery
don't switch it . Electrics make noise . U may lose some acceleration when it kicks on. thats like down grading.
5spd V6 ClrTail is offline   Reply With Quote
Old 03-22-2004, 01:52 PM   #12 (permalink)
I'm a Mac
zoni's Avatar
why???
thats like saying listening to your radio will make you lose some acceleration when it is on.......
i think the added stress on the PS pump is more to worry about than the use of power from the battery...cause that actually affects the engine.
I just chose the electric fan cause it leaves you more room in the engine bay. Simple as that. BUT, you do lose out on the PS fluid cooler.
Dave Zoni
Old 03-22-2004, 02:29 PM   #13 (permalink)
I am just a newbie!
Originally posted by Zoni_Camry
why???
Average power consumption for a engine fan is about 12-14A... that should be enough to add enough load to the alternator and affect acceleration. It obviously has enough load to even cause your idle to fluctuate. When the car is running, all the power usage is supplied by the alternator and not the battery.
On the other hand, I have never notice a power loss when I turn on my stock hydraulic fan. The power steering is being driven all the time regardless if the fan is on or off, and it just diverts the pressure from the PS to the hydraulic fan. The steering wheel actually becomes slightly stiffer as the fan turns on.
Old 03-22-2004, 03:48 PM   #14 (permalink)
I'm a Mac
zoni's Avatar
true.
Dave Zoni
