Tach wiring : 2001 Camry CE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2010, 12:15 AM   #1 (permalink)
View BigDogg's Photo Gallery
Have: Sunpro supertach 3. DIS w/2 coil packs. 5sfe. (1) set cylinder switch for 4 cylinder,or,2?(I've seen it mentioned for DIS to use the 2 cylinder setting.)Green "signal"wire,off one of the coils-like the #1,or,from the ignition module?
The red power wire,that could be tapped into the fuse for the ignition in the driver's side fuse-block,right?
Any help with this would be much appreciated,
Tx.
BigDogg is offline   Reply With Quote
