abs need abs pad? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-22-2004, 09:31 AM   #1 (permalink)
View neck's Photo Gallery
abs need abs pad?
do abs brakes need abs pads?
there seems to be pads for abs and pads for non abs. i take it if i put non abs pads in abs brakes.. abs will nto work.
96 camry V6
neck is offline   Reply With Quote
Old 03-22-2004, 09:59 AM   #2 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700765
iTrader Score: 6 reviews
View EKam's Photo Gallery
There's no difference, ABS is a system; it still uses the same brake caliper.
I believe if a shop ask and you say non-abs, they automatically assume you have drum brakes instead.
18/6/08 - Sayonara Kamuri!
EKam is offline   Reply With Quote
Old 03-22-2004, 12:26 PM   #3 (permalink)
when i bought my PBR pads, it asked specifies w abs and w/o abs. my abs don't work and i was wondering if it could be the wrong pads.
96 camry V6
Old 03-22-2004, 12:46 PM   #4 (permalink)
EKam's Avatar
If it fits on the bracket, then don't sweat it.
Old 03-22-2004, 02:53 PM   #5 (permalink)
it fits. the abs dont' work. but i get no abs light on the dash.
went to dealer.. they told me it's working fine. but it dun work.
96 camry V6
Old 03-22-2004, 03:34 PM   #6 (permalink)
EKam's Avatar
That's another problem unrelated to your brake pads.
Have you ever try slamming the brakes at 120mph? Maybe you're just not driving fast enough for ABS to do its job.
Old 03-22-2004, 03:40 PM   #7 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
malfunctioning sensors? Have a technician pull codes.
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 03-22-2004, 09:56 PM   #8 (permalink)
it seems that abs stopped working after i changed the pads.
and actually.. i slammed the brakes doing 120 mph.. j/k.. but i drive on snow and wet surfaces and it does not work... it simply locks even when travelling high speeds...
Phi: no abs light on.
96 camry V6
