Major Service @ 72 months/ 96000 km? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-13-2010, 01:20 PM   #1 (permalink)
icqboy51's Avatar
View icqboy51's Photo Gallery
Gen5 please delete
thanks for the advise!@
[Gen5 - DIY] Footwell CCFL
http://www.toyotanation.com/forum/signaturepics/sigpic169867_1.gif
icqboy51 is offline   Reply With Quote
Old 05-13-2010, 05:35 PM   #2 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
Why not just ask the dealership about the fuel system inspection? It sounds like they're just going to tell you to do an EFI cleaning which is cleaning the fuel injectors and throttle body.
Is there any reason why you're changing your timing belt already @ 60K miles? That's definitely very conservative but it all depends on if you want to chance going further on it. I'd go ahead and change the water pump because then there's no "extra" labor as everything is apart already. Have you changed your coolant in the past? Your '02 has Toyota Long Life (red) coolant which is good for 24 months or 24K miles. So if you haven't gotten it changed yet, you might as well.
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 05-13-2010, 09:52 PM   #3 (permalink)
icqboy51's Avatar
the recommended interval is 6 years or 96000km for timiing belt.
even though my car has low mileage, it has been 6 years.
also the car is taking that extra second to start up. i think it might be the spark plugs...
yea i took care of the coolant. thats why i dont want my mechanic to touch the coolant. dont want them to put green coolant in...
Old 05-14-2010, 07:57 PM   #4 (permalink)
My mom did the timing belt on her '95 1MZ @ 74K miles in '04. I guess it depends on a) the condition of your belt and b) how conservative you are. I'm fairly conservative with my maintenance but on a non-interference motor it's not as bad as far as the timing belt goes.
How old is your battery? I noticed my 2AZ taking a little longer to start than usual so I replaced my 5yr old OEM battery with a new one from Costco. Immediate difference in the amount of time my car takes to start.
moving forward
Old 05-14-2010, 11:58 PM   #5 (permalink)
icqboy51's Avatar
the battery is the one that came with the car when it was brand new from the dealership so 8 years.
Old 05-18-2010, 06:59 AM   #6 (permalink)
^ I'd definitely replace your battery if that's the case. I change my batteries out at 4-5 years max due to the hot climate and short trips. I need to make a trip to Costco shortly to replace the original battery in my aunt's 2005 Avalon.
moving forward
Old 05-20-2010, 05:25 PM   #7 (permalink)
icqboy51's Avatar
