Camry XLE Valet Key does not function properly in the trunk - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2010, 05:13 PM   #1 (permalink)
View bentleyjrt's Photo Gallery
I have a 2007 Camry XLE, 4 cyl. I have a valet key that functions properly in that it does not open the glove box or back seat armrest passthrough to trunk. However, the trunk, which is the one thing I most care about the valet key not opening, does open with the valet key. What is the trick to having the valet key function properly (not open) in the trunk? My dealer does not know. My car is about to go out of warranty.
bentleyjrt is offline   Reply With Quote
Old 05-17-2010, 06:05 PM   #2 (permalink)
spp
View spp's Photo Gallery
Use the master and turn the key cylinder to the left 90 degrees and remove.
Valet key should not allow you to do this.
Also keeps the trunk release from working inside the cab but the button on the master key will.
If I got any part of that wrong I hope NJerald sets me straight.
spp is offline   Reply With Quote
Old 05-18-2010, 04:55 AM   #3 (permalink)
View Wild_10's Photo Gallery
The valet key will allow entry into the car, which then the floor lever will allow entry into the trunk (even though the valet key doesn't directly open the trunk).
TirePressure.....Each of the 5 tires has a transmitter, which transmits it's 7digit ID# and it's pressure. The TPMS computer monitors these to ensure all are within tolerance. If you have to replace a sensor, be sure to have the tire dealer write down the new ID#. There is a dealer initialization process that they go thru, using a hand held TPMS tool.
The service manual for TPMS, indicates that there is a small black reset button to the left of the glove compartment (after opening it). I haven't personally done this, and proceed further on your own risk....all standard legal and self diagnosis disclaimers apply. It appears that the reset process is as follows. Inflate all the tires to their correct pressure. Turn on the Ignition, hold the reset button for greater than 3 secs. When the initialization begins it will blink the TPMS light 3 times, on and off for a second each. The TPMS ECM will then begin reading the sensors, taking approximately a minute per read. The initialization is completed, when the ECM reads successfully from all 5 sensors the pressure.
Note: it is not real clear to me whether this reset process can be used if a sensor was replaced, or whether this is just used to reset after a low tire pressure detection. There is a separate area of the TPMS service manual, which has a statement that the dealer intialization has to be used to 'register' the new TPMS ID.
Wild_10 is offline   Reply With Quote
Old 05-18-2010, 12:37 PM   #4 (permalink)
First Toyo was '69 Corona
RickF's Avatar
View RickF's Photo Gallery
Actually, that's only correct if you didn't follow 'spp's' advice above your post. If you use the master key to turn the trunk lock to the left 90 degrees (and remove key), the trunk release lever inside the car will be disabled.
2005 Camry 2.4L
2AZ-FE I4 — 2009 Camry 2.4L 2AZ-FE I4
RickF is offline   Reply With Quote
