anyone have rattling/clicking noise problems? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-24-2004, 09:15 PM   #1 (permalink)
View tightcamry129's Photo Gallery
for those of you that have the gen 4 camry (or any other camrys) i have a question for you. do your camrys make weird rattling, clicking during morning start-ups? the noice comes from the left side of the engine (the belts side) you can really hear it outside though. After the engine warms up, the rattling sound goes away. It's just during the morning start-ups. any ideas?
tightcamry129 is offline   Reply With Quote
Old 03-24-2004, 11:50 PM   #2 (permalink)
cam2Xrunner's Avatar
the first thing i would try would be to chage the serpentine belt and go from there. Also use a stethiscope and listen to each pulley. but im thinking serp belt. how many miles are on your car?
Old 03-25-2004, 05:39 AM   #3 (permalink)
i have about 101K miles on my car as of now. You know... i'm really worried because i've been searchin and i found a pretty convincing thread that the problem might be piston slap. Before a decent amount of oil gets inside the cylinder (morning start-ups), the piston has enough clearance and not enough insulations (oil). So basically, it has the clearance to bang around the piston and create such noises during start ups... i kind of believe this because if there is enough clearance INSIDE the cylinder, the oil will seep inside the cumbustion chamber and my engine will burn oil, right? and sure enough, when i checked my back bumper and trunk lid, there was brownish dust layered on top of them. please... help....
Old 03-25-2004, 06:38 AM   #4 (permalink)
The Regenerator
ekpolk's Avatar
View ekpolk's Photo Gallery
I've never heard of piston slap being an issue in a Toyota, although I guess it could be. As I understand it (someone feel free to tell me if I'm wrong about this -- it happens more often than I'd like to admit...), the term has caught on as a result of another bit of poor GM engineering (so what's new). Apparently, to save a few pounds in their current generation of "Vortec" truck V-8s, they chose to make the pistons out of a light alloy that expands greatly when heated. Hmmmmm, pistons and heat, how would those two ever come together (see, I too can be a GM engineer). Anyway, the expanded pistons in a lot of these engines are apparently striking the bottom of the head causing the noise that gave life to the term "piston slap." Whether or not the mechanism you describe could cause noise is an interesting question. I'm speculating that if you had enough slack in the structure to allow such movement, you'd already be suffering overwhelming wear problems.
ekpolk is offline   Reply With Quote
Old 03-25-2004, 07:05 AM   #5 (permalink)
please enlighten me a bit, what does GM have to do with toyota? are they the same company now?
Old 03-25-2004, 08:55 AM   #6 (permalink)
The Regenerator
ekpolk's Avatar
Other than a few minor collaborative deals, not much. And frankly, I hope it stays that way. My point was simply that "piston slap" is a known major issue for certain GM products, but this is the first time I've heard it mentioned with respect to a Toyota. That, in turn, makes me suspect (and it's only a suspicion -- I'm not offering this as gospel) that piston slap is an improbable answer. But maybe it IS your problem; only detailed diagnosis will reveal the actual truth. None of us are going to be able to speculate you to the answer you are seeking.
Old 03-25-2004, 10:59 AM   #7 (permalink)
back again? yeah, i am.
Erbe's Avatar
View Erbe's Photo Gallery
i dont get a lot of clicking sounds but i do get some vibration during the morning start ups
back for the very first time.
-pat
Erbe is offline   Reply With Quote
Old 03-25-2004, 11:30 AM   #8 (permalink)
Man on a mission...
View SKYravefever's Photo Gallery
Have you changed your timing, accessory belts/water pump (all of them are usually done at the same time)? I've had the exact same problem, and after having it done, it was gone.
Could also be that your lifters needing adjustment.
Time is never wasted when you're wasted all the time.
SKYravefever is offline   Reply With Quote
Old 03-25-2004, 12:21 PM   #9 (permalink)
Diablo
View GaviN's Photo Gallery
Mine vibrates hard for the first minute after of starting it up in the morning then it idle's higher and smooths out.
93 Camry LE & 05 Altima SER-6sp
GaviN is offline   Reply With Quote
Old 03-25-2004, 12:29 PM   #10 (permalink)
Boss Honky
YESCA's Avatar
iTrader Score: 29 reviews
View YESCA's Photo Gallery
I used to get that in the morning and like you said it goes away after awhile but it will get gradually worse and not go away....so I changed my timing belt and everything is now ok. Just have your dealer check it out, they don't charge anything to look at it.
OG Team HAMSTER
O.G. Team HAMSTER violated my mom for food stamps
OHIO FORCE!!!
YESCA is offline   Reply With Quote
Old 03-25-2004, 12:55 PM   #11 (permalink)
oh, i see... i have not replaced my timing belt nor the water pump yet....
Old 03-25-2004, 01:31 PM   #12 (permalink)
Man on a mission...
^ @101K you ought to as a preventive maintanence thing. You'll eventually need to do it anyway. Wouldn't want to get stranded.
