Installed a strut bar.... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-02-2002, 01:23 PM   #1 (permalink)
All Show But No Go!
View Eniffey's Photo Gallery
Hey I just installed my front strut bar and noticed that it touches an engine pipe at the top a little bit. I turned it on and it had no problem. But is it suppose to touch? And should i tighten the bolts as tight as possible. Thanks for responding!
Eniffey is offline   Reply With Quote
Old 04-02-2002, 01:35 PM   #2 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
Yeah the clearence is pretty tight. I've heard that if you rotate that bar 180 degrees it might help.
Phi is offline   Reply With Quote
Old 04-02-2002, 01:37 PM   #3 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700765
iTrader Score: 6 reviews
View EKam's Photo Gallery
Use a torque wrench, and don't let the bar touches the intake manifold (better to be safe than sorry).
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 04-03-2002, 03:30 PM   #4 (permalink)
RUN WHAT YOU BRUNG
View 92CAMRYGTS's Photo Gallery
what year car cam did you install it on? what engine does it have?
92CAMRYGTS is offline   Reply With Quote
Old 04-03-2002, 03:56 PM   #5 (permalink)
View phat555's Photo Gallery
Wassupp, when I install a strut bar what kind of tool should I use to take off the nuts? Is it tight that i would have to use a power tool? Does anything fall out when I take out the nuts? Thanks.
phat555 is offline   Reply With Quote
Old 04-03-2002, 04:56 PM   #6 (permalink)
RUN WHAT YOU BRUNG
no nothing will fall out if you undo the screws.use a rachet. the nuts aren't that tight where you need a power tool. so use a rachet and the right size socket. i forget what size it is so just try a couple and see which one fits best. then loosen and take off the three nuts put on the bar and then tighten the nuts as tight as you can. then after that, tighten the nuts on the end of the bar to extend it until they are tight.
Old 04-03-2002, 04:58 PM   #7 (permalink)
RUN WHAT YOU BRUNG
this one of the easiest things you could do toyour car. practically no work all. it tok me about a whole 2 minutes to put mine in.
Old 04-03-2002, 05:02 PM   #8 (permalink)
EKam's Avatar
I wouldn't listen to you if I were to do mine. If you tighten it too much you might snap the bolts during hard cornering and your whole suspension might fall out! (Ok that might be too much but it's still not a pretty sight...)
Old 04-03-2002, 06:22 PM   #9 (permalink)
budking686's Avatar
View budking686's Photo Gallery
55-60 pounds of torque per nut
you can reach me on AIM @ budking52r
1996 Camry 2.2L
Waiting until I graduate to buy a 2005 Toyota Tundra V8!
budking686 is offline   Reply With Quote
Old 04-03-2002, 09:30 PM   #10 (permalink)
View speedemn's Photo Gallery
I thought it was 35 lbs of torque per nut for the front strut tower brace. 6 nuts in all.
2003 BMW 540i 6-spd
2008 Toyota Rav4 Limited V6
2005 Mazda 3 Sport GT 5-spd (just sold)
1995 Nissan Maxima SE 5-spd... Best ET: 13.8... Best trap: 99mph (Gone)
1993 Toyota Camry LE (Gone)
speedemn is offline   Reply With Quote
Old 04-03-2002, 10:15 PM   #11 (permalink)
RUN WHAT YOU BRUNG
ok maybe not as tight as you can but i dont have a torque wrench so i have to go by how it feels. i did all my suspension and nothing has broken. without a torque wrench its hard to be specific about how tight to tighten something. what is tight to him my be loose to me. it all depends n how stong you are and how mush you an tighten.
Old 04-03-2002, 11:24 PM   #12 (permalink)
View woshiagni's Photo Gallery
From Luc a while back:
Front (all in ft-lbs): 1) strut upper mounts: 59, 2) strut-to-suspension support (damper shaft) nut: 36, 3) strut-to-steering knuckle nuts: 156 for Camry, 162 for Solara, 4) stabilizer bar link to strut: 29
Rear (in the same format as above): 1) 29, 2) 36, 3) 145, both Camry and Solara, 4) 29.
It's also 59 in my Haynes...
Hope this helps. =)
- Jeddy
woshiagni is offline   Reply With Quote
Old 04-04-2002, 06:40 PM   #13 (permalink)
How do i know when it's 59 lbs?
Old 04-04-2002, 07:33 PM   #14 (permalink)
RUN WHAT YOU BRUNG
you need to buy a torque wrench
Old 04-04-2002, 08:01 PM   #15 (permalink)
All Show But No Go!
Thanks guys for replying. Never knew that I'll have so many reply's.
