Radiator Fan not turning on when Idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-27-2010, 03:05 PM   #1 (permalink)
View texas_camry's Photo Gallery
2000 Camry 4 cyl
Both fans turn on after I turn the AC on but if the AC isnt on neither fan will turn on. I have recently replaced the radiator due to a crack in the radiator. Any suggestions/help would be greatly appreciated.
texas_camry is offline   Reply With Quote
Old 07-09-2010, 09:32 AM   #2 (permalink)
View rnaz1017's Photo Gallery
4th Generation
That's normal. I've had my 4 banger camry for 12 years and the cooling fans rarely go on at idle. The engine doesn't get too hot idling unless you let it idle for a pretty long time closer to 10 Min's before the fans come on..and even if they do they only stay on for a minute or two.
rnaz1017 is offline   Reply With Quote
Old 07-09-2010, 05:38 PM   #3 (permalink)
Gameroom cash: $304355
^ What rnaz1017 said. The only addition I can make is that at idle only one fan will come on to cool the radiator, not both fans as happens with the A/C.
Mike
Old 07-17-2010, 01:49 PM   #4 (permalink)
Dogging It
judge34411's Avatar
Gameroom cash: $116690
View judge34411's Photo Gallery
It is all electric with temp sensors. They come on when needed. The A/C loads up the engine and causes them both to work. Just check temp gage you will see if working or not.
judge34411 is offline   Reply With Quote
