Another indiglo gauge question
Well I have a generation 4 camry with the indiglo's installed, but of course there is a problem...
The indiglo's look fine by day, but by night they do not work (not doing what intended to do) only the regular backlights of the old gauges light it up.
The indiglo's were *supposed* to work when hooked up to the headlights, everything I believe was plugged in correctly.. Because I thought there was something wrong with the power converter for te gauges I bought an entire new set (same thing)
This time before re-installing the gauges I hooked up the 12v to the car battery....but the new set did not work(mind you the car was on and the switch was turned on, and the lights were off)
soooo Im getting a little angry at the whole thing, what do I do from here ???
