It's a 1987 Camry, the original motor seized and was swapped out...
It cranks, but won't catch. Getting fuel, fuel pump works fine (tested both).
Before car seized, no starting problems. So I'm temporarily ruling out the ignitor...
Replaced dist. cap and plug wires, no difference. No spark at all.
Primary coil measures .7-.9 ohms (Manual says .4-.5ish, but the original-seized-motor also measures the same, but it ran??)
Secondary coil within specs. The N-/GE/N are all within the specs also.
What I know:
The little "two clip" connector up top, is delivering only 5.5V (?!). 5.5V on the -, and 12V on the +.
When plugged into the distributor, both the - and the + on the coil become... positive?! (As in one multimeter lead on the terminals, one on the ground. Both become the same?)
And thus, no "voltage" on the terminals itself. Confuzzling
Help PLEASE!
