Originally posted by Admiral
I recently replaced my suspension system. I put tokico struts. Eiback prokit springs. KYB strut mounts.
But its still noisy. I went over everything again to make sure it was screwed tight. I've put about 300 miles on it sofar cuz i thought it just needed to be broken in. Any suggestions?
On my '00 LE i4, I've had TRD (made by Eibach) and Tokicos for about 3 1/2 years (close to 60K miles) now - all the time with noises. Have changed strut mounts 3-4 times, including KYB once - no luck.
Since I recently had to start driving a lot more in the city, over potholes, I decided to change back to stock springs. I just finished the front today and kept the Tokicos with stock springs. I can tell you, with the same strut mounts that I had with the TRD springs, I no longer seem to have clunking noises !!! I think the TRD stprings (same for Eibach) are probably the problem...
I should be done with the rear of the car probably tomorrow and after I put a few more miles on, I'll let you know if this helped for sure, or is it just an illusion
. If my experiment shows that the problem is the springs, I'd say (unless you have an installation problem) your only option might be to go with Tein H-Tech or S-Tech springs. These are not progressive and are somewhat softer than Eibach in order to have a drop (the S) and at the same time have a quiet ride.
Another observation, the latest strut mount from Toyota (with oval opening on the top) is better than the redesigned previous version - it is firmer and less noisy.
