2000 Camery 2.2 Wont start
I have a 2000 camery 4cy. The timing belt has been replaced and now has around 60,000 miles on it. I was driving about 40mph and the engine just shut off. I have checked all the plugs and they are getting spark. I removed the two upper bolts on the timing cover and looked at the timing belt. It looks to be ok I also checked it while spinning it over and did not notice any slipping. I checked for fuel at the line at the filter and it gushes out when spun over. The fuel pump was also changed about 60,000 miles ago. When I first spin it over I acts like it is going to start for a second and then just spins over. I can let it sit about 5 minutes and the same thing happens. I also hooked up a code reader and it found none.Those are the only repairs that have been done and the car has about 176,000 miles on it, Any ideas?
Just to add a few checks I have done. The car will run when given gas thru the intake.. Maybe the cam sensor? I was told it is for the fuel delivery timing
Thanks, I replaced the cam sensor today 80.00 bucks down the drain... Its killing me that it will run on a little gas in the intake. I have worked at a Caterpillar Dealer for 15 years and have never had a engine I can not fix. This whole Toyota thing is killing me. Maybe its time to do whaI tell our customers and bring it to the dealer, I will keep you all posted.
Reason: additional troubleshooting
