Door panel removal instruction needed! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-28-2004, 06:36 PM   #1 (permalink)
View camry1998's Photo Gallery
Question Door panel removal instruction needed!
Hi there,
I am new to this forum. I want to change the driver side mirror
by myself so I have to remove the door panel to connect the
wire. I wonder if any body has such experience can give me instructions how to remove the panel. The more details the better, e.g., totally how many screws to remove, in what order if matter, and what should pay special attention to, etc.
Thank you very much in advance!
camry1998 is offline   Reply With Quote
Old 03-28-2004, 06:47 PM   #2 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
Lightbulb
You dont have to remove the door, all you have to do is remove the quarter panel by the corner of the door, on the other sid eof the mirror. Its alil plastic piece, and the wires and bolts are right there.
I have a pic mine is white, just remove that piece are your good to go
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 03-28-2004, 07:59 PM   #3 (permalink)
Thanks drewscam. I know what you are saying and I know I should remove that triangle stuff to remove the nuts. But I
found the wire goes down and the harness is somewhere in
the door but not beside the bolts. And I cannot pull it out of
the panel. So I think I have to open the panel to disconnect and
connect the mirror wire...
Old 03-28-2004, 08:02 PM   #4 (permalink)
Go camry goooooo
DrewsCam's Avatar
Oh ok, the panel i beleive is held in by screws a few under neath like looking up at the bottom of the door, and one in the middle of the door, there a lil circle plastic piece that pops out and theres a screw underneath it
Hope that helps
Old 03-28-2004, 10:06 PM   #5 (permalink)
Yeah I think so, after searching on the net.
So what I want to know is more details because I
never did that before.
Old 03-28-2004, 11:14 PM   #6 (permalink)
By searching this forum, I found this site:
http://carstereohelp.com/stereoremov...mry1FDrSpk.htm
This one is very helpful! I am going to try it as my mirror arrives.
