I have a problem similar to this guy:
Soft brake pedal when car is on--booseter issue?
When car is running, the pedal's mushy. Constant pedal pressure doesn't drop the pedal to the floor. I'm not leaking brake fluid. I don't think it's the brake lines. Lines have been bled multiple times.
I do hear a vacuum leak. It gets pretty loud when then engine is on and I press the brakes. The leak is at the bottom of where the master cylinder and brake power booster meets. In fact, with the brake pedal depressed, I can feel air coming out of the junction.
With the engine on, brake pedal depressed, I can turn off the engine and the pedal pushes up at me and gets rock hard. With other cars, this doesn't happen. In fact, on other cars, I can usually get another pump on the pedal, but my car doesn't.
I'm certain it's a vacuum leak, but I'm not sure if I need to replace the master cyl or the brake booster. Any ideas on how to diagnose this? I can't go a day without the car, so can't have down time to order necessary parts, nor do I want to spend $$$ on buying both.
Thanks!
Dr J
