Hey Luis !
I know the problem. I did have the oil lines provided but I had to custom build the water ones. I used little metallic tubes that I welded on small metallic plates, drilling a whole in the middle and connected to a rubber hose going to water lines.
As for oil lines there are a few aftermarket oil (feed and return lines sold on ebay. However I don't think they fit the ct26 that well. I would try to custom build them as well, also this is much cheaper. You could use metallic tubes and weld them. I am just trying to give ideas I hope it helps. Sorry I don't have pics of the turbo right here but it's not complicated : the two holes at their two opposites are for water, the third whole (which has in fact two holes, one big and one smaller ) is for oil : the small one is the feed line and the big one is for return.
I know such kits sellers won't sell you their parts separately (I tried many of them) but have a look on ebay and see if something can help you.
Good luck !
Nico
