Drive light on gauge went blank - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-31-2004, 11:19 AM   #1 (permalink)
View HandedMyOwnLife's Photo Gallery
Hi people,
I have a '98 camry, when I shift the gear into drive mode, the light does not come on. All of the other gears like P, N, ...ect are still on. Is the light buld for D (DRIVE) blew or that? Or is there a guse that I need to replace? If so, where?
Can someone give me a feed back on what might be wrong with the light? Before, the light came on but I think it just got burn recently.
Is the replacement of fuse/bulb for this job hard? Can it be done at home or dealership? Would there be some malfuntion that I might face if touching of the chips or anything of electronic when I open up the dashboard to replace the fuse/bulb?
Thanks Guys
PL
HandedMyOwnLife is offline   Reply With Quote
Old 03-31-2004, 11:24 AM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
its just the bulb that burnt out... you can tear apart your dash and get at your instrument cluster to replace it (with your L or 2 light)
mine is burnt out, i like it better that way
-Nick
Nick is offline   Reply With Quote
Old 03-31-2004, 11:27 AM   #3 (permalink)
stealth
badazzlegnd's Avatar
View badazzlegnd's Photo Gallery
mine went out too it was easy to replace in the gen 3 though
badazzlegnd is offline   Reply With Quote
Old 03-31-2004, 12:41 PM   #4 (permalink)
Advanced Noob
brungold's Avatar
View brungold's Photo Gallery
Mines out too, oren's gonna show me how to take my dash apart too to switch my L light with D (right?)
| 1995 Camry LE 5SFE [sold] | 2003 Highlander 1MZFE [sold] | 2006 Tacoma PreRunner 1GRFE [gone] | 2008.5 Audi A3 2.0T [now]
FS: Navone N-85V Line-Out Convertor for connecting amp/sub to Factory HU
brungold is offline   Reply With Quote
Old 03-31-2004, 04:18 PM   #5 (permalink)
Car Breaker
View epborden's Photo Gallery
Yea just happened to me, but I probably broke it ripping out the dash, oh well still drives fine
epborden is offline   Reply With Quote
Old 03-31-2004, 06:13 PM   #6 (permalink)
stealth
Yeah ill help ya
Old 03-31-2004, 06:50 PM   #7 (permalink)
View yosh's Photo Gallery
Re: Drive light on gauge went blank
Originally posted by HandedMyOwnLife
Hi people,
Thanks Guys
It's very easy to do. All you need is a small flat head and a phillips. Use a phillips to remove the two screws at the top of the black plastic trim surrounding your gauges, clock and vent. Then use the flat head to gently pry at the two far ends and the lower corners. Make sure to tape the tip so you don't damage it. Once removed, you will see four screws to remove with your phillips. Then just disconnect the three wire harnesses and you can remove the gauge cluster.
2000 Camry LE V6
TRD Supercharged
yosh is offline   Reply With Quote
