tips on painting emblems (g3) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-31-2004, 11:50 AM   #1 (permalink)
permanent hiatus
ryuji16's Avatar
View ryuji16's Photo Gallery
i already ran a search and got some info, but i still need more.
i know that the rear emblems have pegs and are easy to remove, but someone posted that one of the rear emblems have to be BROKEN to remove. that doesnt sound too good. i also want to confirm that ALL emblems have pegs, so i know i wont have to mark the original positions of the emblems.
i also found nothing on how to remove the front toyota emblem. is it held down by pegs and tape too? i read a post that suggested that it was screwed in. which is it?
one last thing... what size/thickness of double-sided tape should i use, and will i be able to find it at autozone or something?
i plan to sit the car i the sun for a few hours then use floss/goo gone and try my luck. but not before i get some help!
ryuji16 is offline   Reply With Quote
Old 03-31-2004, 02:56 PM   #2 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
Your best bet is to use a blow dryer, put it on high on heat for a lil to let the glue soften up and use dental floss. I have a gen 4 and did that all i have on my rear is the t symbol, which i got painted and the autobody shop,it is the same color as my car.
So it all matches and blens in nicely
And to put back your emblems use a thin tape or even a model glue thats what i did on my emblem the first time i painted it, and i had no problem taking it off
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 03-31-2004, 05:32 PM   #3 (permalink)
permanent hiatus
ryuji16's Avatar
thx for the help, but my main concern is how to take off the front emblem and the issue of breakage. this is for a gen3, so it is probably different from working with the g4's emblems.
is the front emblem the same as the rears?
three liters est. 1992
1.5 liters est. 2006
Old 03-31-2004, 06:05 PM   #4 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
the front one in the grille?
its held in by a couple screws, have a look
-Nick
Nick is offline   Reply With Quote
Old 03-31-2004, 06:14 PM   #5 (permalink)
back again? yeah, i am.
Erbe's Avatar
View Erbe's Photo Gallery
since were on the subject of the front grille....how do you remove all the other stuff on the grille so its empty in the middle
back for the very first time.
-pat
Erbe is offline   Reply With Quote
Old 03-31-2004, 07:11 PM   #6 (permalink)
permanent hiatus
ryuji16's Avatar
thx oldman, i was gonna just pry it off. so i gotta unscrew from behind right?
Old 03-31-2004, 07:37 PM   #7 (permalink)
mox
God Machine
mox's Avatar
View mox's Photo Gallery
Use a dremel tool
'92 Camry SE V6 5 Speeds (Pics: 1 | 2 | mox.monchar.com) ('06-now)
Previously owned: '99 Corolla,MT ('99-'01), '97 Camry XLE V6,AT ('01-'02), '92 Camry SE V6,MT ('02-'04), '99 Solara SE V6,MT ('04-'06), '93 Camry LE V6,AT ('06-'07)
mox is offline   Reply With Quote
Old 03-31-2004, 08:06 PM   #8 (permalink)
Nick's Avatar
i used a metal saw blade
-Nick
Old 03-31-2004, 09:14 PM   #9 (permalink)
Layd Customs
View InTeReX's Photo Gallery
or u could just remove the front grille itself.
Pop the hood and there are two bolts on either side or the grille (use a socker wrench or whatever u prefer) take them off and then just pull your grille up.
Turn it over and there are three screws holding the emblem on. take them out and your emblem will come right off!
then go at it with the dremel if your gonna work on clearin out the middle of it. makes it easier when u can hold it
good luck
InTeReX is offline   Reply With Quote
Old 04-01-2004, 07:50 PM   #10 (permalink)
permanent hiatus
ryuji16's Avatar
ok thx interex. im guessing there is no way to remove the front emblem w/out removing the grill... or is there?
Old 04-01-2004, 08:25 PM   #11 (permalink)
Nick's Avatar
you could get at it, but its much simpler to take off the grille, its just held in by 2 screws anyways
-Nick
Old 04-01-2004, 10:18 PM   #12 (permalink)
Lives For The Curves
View nort0188's Photo Gallery
[rant] Do you guys even look at your cars before you ask these questions? The front grille has to be the absolute easiest part of the car to deal with. Two screws hold it in place, three screws hold the emblem on. If you just take a look, you would know this. Sorry to be a bitch about it, but damn... at least TRY to figure it out for yourself. [/rant]
If torque actually won races, wouldn't we all be driving diesels?
nort0188 is offline   Reply With Quote
Old 04-02-2004, 02:45 AM   #13 (permalink)
permanent hiatus
ryuji16's Avatar
ok man... youre totally right, my mistake. just be cool
btw i usually break something whenever i try to "figure things out". i was just trying to cover all the bases before hand.
thx to everyone else for the help
Old 04-02-2004, 12:03 PM   #14 (permalink)
Layd Customs
no worries man...this is suppose to be a "helpful" forum.
if u don't know, then ask.
But do a search first to see if it has been covered before!
GoodLuck
Old 04-02-2004, 05:35 PM   #15 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
You guys should put this in the sticky, it's good info.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
