Where to Get 10mm hubcentric spacers? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-31-2004, 07:59 PM   #1 (permalink)
View le0331's Photo Gallery
I know H&R sells hubcentric spacers but they only come in 5 and 15 mm. Trying to get 10mm HC spacers, anyone know where?
Would 5mm hubcentric spacers be wide enough to clear IS300 rims with 50 offset, especially in the front? I have 10mm spacers that aren't HC but from what I read, HC spacers are the way to go and the cheaps ones will not work. 15mm HC spacers are a bit pricey so I'm trying to stay away from them.
le0331 is offline   Reply With Quote
Old 03-31-2004, 08:22 PM   #2 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
does this help?
http://www.prestigewheel.com/ImageC7100.asp
You might consider getting longer bolts too.
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 03-31-2004, 08:24 PM   #3 (permalink)
stealth
badazzlegnd's Avatar
View badazzlegnd's Photo Gallery
Do you need spacers to fit is300 rims on a camry?
badazzlegnd is offline   Reply With Quote
Old 03-31-2004, 11:57 PM   #4 (permalink)
View JTLCastro's Photo Gallery
yes and no for the IS300 rims. It all depends on your tire and suspension setup. I have them with the combo that most said would not rub, 215/45/17 and yet they still do. The tires are dunlop and have the new curb/rim guard so that the sidewall sticks out just a little. The front is okay but the rears rub. Most of you will not have that problem, but I run the JIC coilovers and it seems like i just need it out 3mm. I ordered the H&R hubcentric spacers for them. the front still have an amazing over 5mm space so you dont have to worry. 50 series i hear you will rub. anything fatter than 215, you will rub. you need to get spacers.
1997 V6 Camry XLE:JIC FLT-A1US Coilovers, JP Performance Headers & Y-Pipe Combo, TRD Front strutbar, TRD RSB set to "track", IS300 rims with 17x7 215/45/17 Z-rated Dunlops. H&R Hubcentric 5mm Spacers
AIM: xHerManJohnx Email:JTLCASTRO@yahoo.com
JTLCastro is offline   Reply With Quote
Old 04-01-2004, 12:04 AM   #5 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
If theyre hubcentric, wouldnt it be possible to stack two 5mm ones on each other?
ratko.org
Ratko is offline   Reply With Quote
Old 04-01-2004, 08:54 AM   #6 (permalink)
Originally posted by Phi
does this help?
those spacers aren't hubcentric...
looked everywhere but no one seems to have 10mm hubcentric spacer for the camry. Found this site FK spacers but they only operate in Europe. Would 15mm spacers be too much?
