Engine Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2004, 08:50 AM   #1 (permalink)
Sold out for a Max
TheMajesticking's Avatar
View TheMajesticking's Photo Gallery
Engine Problem
Hi I just purchased I '93 Camry XLE V6 about 1 1/2 months ago. I just changed the oil yesterday to Mobil 1 10w30. I have been getting a low idle about 5-6 secs after a complete stop. Could it be because of the oil? What causes a low idle? It goes down to about 700-750 rpms.
-Chris
TheMajesticking is offline   Reply With Quote
Old 04-01-2004, 08:53 AM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
the idle should be 750rpm...
-Nick
Nick is offline   Reply With Quote
Old 04-01-2004, 08:55 AM   #3 (permalink)
Sold out for a Max
Well maybe its lower than that. It starts to drop and as it drops down the car starts to shake then after 6-7 secs it goes back up.
-Chris
Old 04-01-2004, 08:57 AM   #4 (permalink)
Nick's Avatar
clean out your throttle body and idle air controller
-Nick
Old 04-01-2004, 09:00 AM   #5 (permalink)
Sold out for a Max
Thats not the first time I've heard that. How do I do these things. The search didn't help. I also saw a post that you told somebody how to do a ghetto tranny flush. How do I do that too?
-Chris
Old 04-01-2004, 09:08 AM   #6 (permalink)
View Nico's Photo Gallery
It's either the IAC or the TPS but it's more likely to be the IAC (I would think)
Well you just have to disconnect the air intake tube going to the throttle body, start engine and spray carburator cleaner, clean with a teeth brush. There is a very detailed procedure on this website if you use the search button. Good luck !
Nico
Nico is offline   Reply With Quote
Old 04-01-2004, 09:23 AM   #7 (permalink)
Sold out for a Max
Is 10w30 Mobil 1 right or should something different as far as weight?
-Chris
Old 04-01-2004, 09:26 AM   #8 (permalink)
This oil is very good for the engine. And it is by no mean the reason of your problem.
Nico
Old 04-05-2004, 07:54 AM   #9 (permalink)
View haa21's Photo Gallery
I use 5W30 Mobile 1 in my 2000 V6 Camry. I have never had a problem. Check your owners manual to see if 5W30 is more appropriate. The 10W30 won't hurt.
haa21 is offline   Reply With Quote
Old 04-05-2004, 08:10 AM   #10 (permalink)
Sold out for a Max
I had just changed my oil last week. Come to find out, I only put in 4 qts. I added oil and haven't been having the problem. Thanks though. I kinda semi-cleaned the throttle body but the problem doesn't persist. Thanks guys. I went ahead and did a ghetto CAI while I was at it.
-Chris
