The lug nuts should work. Do the rims work though? How wide are they? Are they different width's between front and rear? Also what are the offset(s)? You might need H&R hub-centric spacers for the rear.
Toyota OE lug nuts for their alloy wheels are sorta special... they have a built-in washer that I haven't ever seen before on aftermarket lug nuts or "regular" lug nuts.
Originally posted by 88 LE It doesn't matter if the SC400 and your Camry uses the same size lugnuts (12mm x 1.5 or whatever it is).
What you need is lugnuts that'll fit your Camry and has the right style seat for the SC400 wheels.
The stock lugnuts on your Camry most likely have a acorn style seat. In other words its a tapered seat.
SC400 wheels have a flat seat, so you need a lugnut with a shank on it. Its either a short shank or long shank, i'm not sure which.
Are you sure the offset on the SC400 wheels is 35...42?
I have a set of SC400 wheels and it says: Toyota 16x7JJ 50. I'm thinking its a 16x7 with 50mm offset.
I believe 50mm sounds more like it. I havent gotten my wheels yet. I got 35...42 from websites
So how would i find out if the sc400 wheels need a long shank or short? Can this problem be fixed easily by a shop or will i havta buy something on top?
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
With my old Lexus IS300 wheels, the ONLY lugnuts that would work on them properly were the OEM Lexus lugnuts. So my answer would be no to using your original Camry lugnuts. Like 88LE said, most Lexus wheels (including the IS and SC) use a special washer-type seat on their nuts.
Originally posted by Ratko With my old Lexus IS300 wheels, the ONLY lugnuts that would work on them properly were the OEM Lexus lugnuts. So my answer would be no to using your original Camry lugnuts. Like 88LE said, most Lexus wheels (including the IS and SC) use a special washer-type seat on their nuts.
Originally posted by 604-Mico Ok so you were refering to specific washer lug nuts right
so is the following what you were referring to?
Do you think this is the correct application? http://cgi.ebay.com/ebaymotors/ws/eB...tem=2469924324
