spacer conversion - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-26-2010, 07:34 AM   #1 (permalink)
The guy with a maroon 92
n3rdifed's Avatar
View n3rdifed's Photo Gallery
3rd Generation spacer conversion
Ok so ive picked up a really good deal on a set of wheels (175$). check it out:
heres the specs on this set:
16x8
staggered +0 +16
tires are way too bulky so im going with a 225 50 16. (the current tires im running on the ls400 rims)
with this set i can accomplish my "flush" look. fenders will be rolled for 40 each fender. but theres a problem, caliper clearance and bolt pattern is just a bit off. but with a combination of this problem for fitment, comes a conversion spacer. im looking to convert from 5x114 to 5x120.7 to fit these rims on with around 15mm on all four hubs for clearance.
see that? FLAT. no clearance whatsoever. but during the test fit i measured the space between the outer edge of the caliper to hub and its around 15 mm give or take.
if anyone can help me find some conversion spacers in those specs id greatly appreciate it. thnx.
n3rdifed is offline   Reply With Quote
