Removing a/c compressor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-05-2004, 05:02 PM   #1 (permalink)
View itsmycookie's Photo Gallery
how do you get it off, i already have a belt, and took out to bolts on the bottom of the compressor but i have had no luck. so basically what else do i need to remove to get it off? Or should i just hit it really hard with a hammer?
itsmycookie is offline   Reply With Quote
Old 04-05-2004, 05:09 PM   #2 (permalink)
View Nico's Photo Gallery
What car do you have ? Apart from 4 bolts, a/c lines and the harness I don't see what could be the problem to remove it
Nico
Nico is offline   Reply With Quote
Old 04-05-2004, 05:52 PM   #3 (permalink)
wow i can't believe that i forgot to post that
it is a 92 sedan inline 4
i took off two bolts off the compressor that i can see
where are the other bolts
Old 04-05-2004, 08:21 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The other bolts are on the compressor.
Once you remove all the bolts (4 total) the compressor will just fall off.
"Skoolin' the unlearned!"
