Clear Coat - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-08-2004, 12:55 PM   #1 (permalink)
Toyota Lover
KerTiZ's Avatar
View KerTiZ's Photo Gallery
Clear Coat
Hey, With all the snow gone, i finally was able to paint my lip pieces for my car. I already primed it and painted it. On my last coat of paint.. am i supposedd to sand it again before i put the clear coat on? cuz if i sand it.. i'll get weird texture marks and it won't look as nice.
KerTiZ is offline   Reply With Quote
Old 04-08-2004, 01:36 PM   #2 (permalink)
Toyota Lover
KerTiZ's Avatar
oh.. i might as well ask this also... Am i supposed to sand between after i apply the clearcoat to make it smooth? or do i just leave it.
Old 04-08-2004, 04:05 PM   #3 (permalink)
That Geeky Star Wars Girl
ripley's99's Avatar
View ripley's99's Photo Gallery
are you wet sanding? and are you using a high grit sandpaper...like 1500 or 2000 grit? b/c that is what i would use, it doesn't leave marks etc.
later,
Keri
99 Camry SXV20 5S-FE "Darth Maul" TRD Grocery Getter
89 MR2 AW11 4AG-ZE "R2-D2" Project nearing completion ...
"Darth Vadar" Super Secret Sith Power Project Car
ripley's99 is offline   Reply With Quote
Old 04-08-2004, 09:08 PM   #4 (permalink)
View chcwf's Photo Gallery
With a base coat clear coat paint system you should follow the recommended process from the paint manufacture. Most say to apply the base color until all primer/sealer is covered , doing this in several coats . You must let each coat of paint flash (that is the amount of time the manufacture has determined it will take at a certain temp. for all the solvents to dry before the next coat is applied . The clear coat must be applied with in a certain amount of time after the last color coat is applied. (clear coat usually is applied 5 minutes to 24 hrs after last coat of paint . If it goes past 24 hrs you must sand and reapply the color and then clear it with in the first 24 hrs. Sanding the clear after it dries is up to you if the clear lays down nice and no dirt is in it then no sanding or buffing is needed.
chcwf is offline   Reply With Quote
Old 04-08-2004, 10:30 PM   #5 (permalink)
View wontonjohnny's Photo Gallery
its almost impossible to get a mirror finish without cut polishing
you should put aleast 3 coats of clear coat
allow the final clear coat to dry for 2 days of good weaher,, and then sand with 600 wet dry then a buffing compound.. that should leave a better than factory finish
5 speed 3vzfe - RIP
project F23 CL-T
Custom Y-pipe Project
Custom 1-Piece CAI Project
wontonjohnny is offline   Reply With Quote
Old 04-08-2004, 10:52 PM   #6 (permalink)
The Greatest
View CamNub's Photo Gallery
How much did that cost ya? You did DIY right?
CamNub is offline   Reply With Quote
Old 04-08-2004, 11:21 PM   #7 (permalink)
Toyota Lover
KerTiZ's Avatar
total cost was 80 bux with tax... for primer, paint, clear coat and sandpaper. I painted the front and rear LIP pieces for the gen 4 TRD kit. I figured i might as well give it a try. It was definatly very fun and i appreciate it much more cuz i did it myself rather then some paintshop (altho.. theres woulda been much nicer probably) >_<
Car Domain Page
Old 04-09-2004, 01:34 AM   #8 (permalink)
war0827's Avatar
View war0827's Photo Gallery
theirs would have been nicer, but...
1. You saved a hell of alot of money
2. The kit isn't gonna stay perfectly painted forever, esp. after driving around for a bit and having crap from the road hitting it.
Plus you get the experience of DIY for next time as well. Post up some pics. I'm pretty sure everyone would like to see how you did. i know i would cause i'm planning on DIY my kit when i get it
Originally posted by Drewscam: ill bring my balls u bring urs
war0827 is offline   Reply With Quote
Old 04-09-2004, 01:47 AM   #9 (permalink)
Toyota Lover
KerTiZ's Avatar
Alright.. here are the pics.. unfortunately.. the match wasn't perfect.. but.. if you see it in person its really hard to tell.. but some reason in the pictures.. they kinda stand out more... also.. no side skirts .. so if any of u are selling your gen4 TRD sideskirts.. gimmie a shout.. i'm in desperate need of em.. even if they are fiberglass ones i'll b fine with it.. =p
Old 04-09-2004, 09:16 AM   #10 (permalink)
View luisitol's Photo Gallery
looks like a good job man. What type or airbrush did you use?
'93 Probe GT - Daily Driver
'93 LE - Show Car - Coming SOON
luisitol is offline   Reply With Quote
Old 04-09-2004, 01:22 PM   #11 (permalink)
Toyota Lover
KerTiZ's Avatar
hmm
i just used those paint cans u buy at Canadian tire. Dupli Color. ^_^
Car Domain Page
Old 04-09-2004, 06:33 PM   #12 (permalink)
Rocket Surgeon
woody's Avatar
View woody's Photo Gallery
Now that the paint dried and cured, you have to sand before painting with clear. Do it by hand with 600 grit wet. I am afraid you might cut through your paint into the primer, but if you do, respray the whole piece with color, then wait about 1 hour (up to 12) and spray the clear over it. I think the duplicolor stuff has recommendations on time. Check canadian tire for the big gallon cans, same stuff, but they have more instruction on them usually.
woody is offline   Reply With Quote
