rough idle & hesitation
I have a 89 camry with auto trans. and I see quite a few questions being asked about rough idle in gear (warm engine) . I have the same problem and some of the suggestions to cure the problem are to replace the I.S.C. motor , has anyone tried this and did it fix the problem? Also I question the EGR valve , it seems to work but I wonder if it is working to well , I mean to much egr on acceleration causing the hesitation just off idle . Has anyone had this problem and did the EGR valve replacement fix it?
