fix a fan... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-09-2004, 12:19 AM   #1 (permalink)
View omeserone's Photo Gallery
fix a fan...
aight heres my problem: my temp. guage rose all the way hot so i stopped and went to autozone and bought a thermostrat.. replaced it .. and it runs fine for now but i realized my fans (netiher of the two) are running (if you spin it with your finger itll keep going without a click noise, they tell me this is bad) so question 1. what do i do now 2. how much is this going to cost more or less to fix...
ps. i own a 1994 toyota camry (4 cyl.)
omeserone is offline   Reply With Quote
Old 04-09-2004, 06:44 AM   #2 (permalink)
View chcwf's Photo Gallery
If you think there bad go get a used assy. from a salvage yard . You should be able to get the hole thing , shroud, motor & blade.
chcwf is offline   Reply With Quote
Old 04-09-2004, 08:12 PM   #3 (permalink)
View dbruce's Photo Gallery
I'd check the clip that connects the fan to the thermostat/power etc before replacing the whole assembly.
dbruce is offline   Reply With Quote
Old 04-09-2004, 08:25 PM   #4 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
frist make sure the fans are bad by putting power to them put jumper wires from you batt. to a fan and see if it works if it does check the fuses and relays if those are fine then there also should be a temperature switch that turn it on go to the part store and ask for that part so you can see what it looks like(advance auto should have a picture of it). hope that helps
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Old 04-09-2004, 10:52 PM   #5 (permalink)
View fe519's Photo Gallery
test out every sections before you go buy all the parts
fe519 is offline   Reply With Quote
