Timing Belt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-09-2004, 08:54 AM   #1 (permalink)
View solidg's Photo Gallery
Timing Belt
I have a 2000 LE V6 Camry with 63k miles. How often should the timing belt be replaced? Is it true that if the timing belt breaks while you are going 60 mph that your engine will be wreaked?
solidg is offline   Reply With Quote
Old 04-09-2004, 09:02 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: Timing Belt
Every 60,000 miles.
Not true.
If the timing belt breaks the engine just stops running.
1MZ-FE is non-interference.
"Skoolin' the unlearned!"
Old 04-09-2004, 02:41 PM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $280492
View csaxon's Photo Gallery
Starting in 1999 Toyota changed the belt material and now recommends 90,000 miles.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 04-09-2004, 11:29 PM   #4 (permalink)
Where di youall gain this info?
Old 04-10-2004, 12:03 AM   #5 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
i saw www.edmunds.com has the maintenance schedule for almost all vehicle that was ever built on earth.
http://www.edmunds.com/maintenance/M...ce.service.3.*
bronzemaxell is offline   Reply With Quote
Old 04-10-2004, 12:40 AM   #6 (permalink)
spyfish007's Avatar
View spyfish007's Photo Gallery
If the timing belt breaks you can lose a significant number of parts in your engine like pistons and valves. Just depends on how "lucky" you get.
spyfish007 is offline   Reply With Quote
Old 04-10-2004, 12:44 AM   #7 (permalink)
camrys blow off too!
View silverstreakin's Photo Gallery
^read sir. its a non-interference engine
93 toyota mark II tourer V
1jz-gte twin turbo goodness!
93 toyota scepter turbo stored back in the states!
*in loving memory rapeacivic*
silverstreakin is offline   Reply With Quote
Old 04-10-2004, 03:58 AM   #8 (permalink)
spyfish007's Avatar
V6 is non-interference ... interesting ... didn't know that. I sit corrected.
Old 04-10-2004, 08:17 AM   #9 (permalink)
Had my timing belt replaced at 50k cause I had to have the main seal replaced. Toyota did it for FREE! Might be a while before it breaks I got 63k now, So i can expect it to happen at 150k.
Good to know. Thanks for posting all.
Old 04-10-2004, 08:29 AM   #10 (permalink)
Grenaded piston
88 LE's Avatar
Timing belt change every 60,000 miles is recommended by the dealer.
I didn't know that Toyota changed the belt material and now recommends every 90,000 miles. O well I'll still change mine every 60,000 miles, better safe then sorry.
As for the 1MZ-FE being non-interference. Most Toyota engines are non-interference, theres a few that are interference though.
Old 04-10-2004, 06:05 PM   #11 (permalink)
Go to Toyota.com, select Owners, select Frequently Asked Questions. This is item #9 Timing Belt Maintenance
Question
What maintenance is required on my timing belt?
Answer
If your vehicle is a 1999 model year or newer and is equipped with a timing belt, you should replace it every 90,000 miles or six years, whichever comes first.
For all other Toyota vehicles equipped with a timing belt, we recommend that the timing belt be inspected with the other drive belts at 60,000 miles or four years, whichever comes first, and every 15,000 miles thereafter and replaced as necessary. Because the costs involved with inspecting the timing belt may be similar to those of having it replaced, many customers may find it more cost effective to replace the timing belt at 60,000 mile intervals.
Old 04-10-2004, 07:44 PM   #12 (permalink)
View Ken4's Photo Gallery
Check whether your engine is non-interference here:
http://www.gates.com/downloads/downl...older=brochure
(note: you need adobe acrobat)
Ken4 is offline   Reply With Quote
Old 04-10-2004, 07:49 PM   #13 (permalink)
View BigDaveZJ's Photo Gallery
I just picked up a used 96 Avalon from a dealer with 70k on it. Is there any way to tell if the belt's been changed?
95 ZJ for the rocks . . .
96 Av for haulin ass!
BigDaveZJ is offline   Reply With Quote
