VERY noobish wuestion sorry!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-09-2004, 07:00 PM   #1 (permalink)
back again? yeah, i am.
Erbe's Avatar
View Erbe's Photo Gallery
Exclamation VERY noobish wuestion sorry!!!!
k....again im sorry for the "noobosity" of this thread but how do u get the jack out of your trunk and use it to jack up the left-front wheel....how do u remove the wheel....thanks...92 cam...i-4
back for the very first time.
-pat
Erbe is offline   Reply With Quote
Old 04-09-2004, 07:10 PM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
ummm, ok...
its wedged in there, so you have to lower it, turn the nob ccw
loosen the lug nuts, set the parking break, put car in park, or in gear (if its manual)
then turn the top part of the jack the groove is sideways, then put it about a foot behind your wheel, crank it up, put the little tongue in the groove and jack it up with the crank that's under your spare wheel cover
-Nick
Nick is offline   Reply With Quote
Old 04-09-2004, 09:02 PM   #3 (permalink)
_trancemaster_
CamryMax's Avatar
View CamryMax's Photo Gallery
*cough*
Toyota Camry '96 LE
I-4 Automatic
http://www.cardomain.com/
"Drive it like you stole it"
CamryMax is offline   Reply With Quote
Old 04-09-2004, 09:04 PM   #4 (permalink)
_trancemaster_
CamryMax's Avatar
Actually, make sure when you take off the wheel, put it underneeth the car (engine area, between the front wheels), because that jack is not the best one. I had my car rolled off the jack when I was changing breaks with my buddy, car landed right on the wheel I had under the car. So be careful.
Toyota Camry '96 LE
I-4 Automatic
Old 04-09-2004, 10:21 PM   #5 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
the car should never roll off the jack if you set it up right... and always make sure to do your work on a level surface
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 04-09-2004, 10:24 PM   #6 (permalink)
_trancemaster_
CamryMax's Avatar
But it did, accidents happen what can I say. Better safe than sorry.
Toyota Camry '96 LE
I-4 Automatic
Old 04-09-2004, 10:26 PM   #7 (permalink)
The Rent is Too Damn High
Deuce's Avatar
View Deuce's Photo Gallery
or just spend $30 and go to Kragen and get one of the hydraulic jacks and stands and not worry about it.
That's just me
I don't need a sig, I'm 31.
Deuce is offline   Reply With Quote
Old 04-09-2004, 10:28 PM   #8 (permalink)
_trancemaster_
CamryMax's Avatar
That's just me
Or a lift like they got in repair shops That gonna come handy for anyting
Toyota Camry '96 LE
I-4 Automatic
Old 04-10-2004, 12:30 AM   #9 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
Weird, my friends car just rolled off his jack today! He was on a level surface but didn't have a brick or anything behind his rear tires.
They really need to make the base for the OEM jack a lot wider....
Silver Streak is offline   Reply With Quote
Old 04-10-2004, 12:40 AM   #10 (permalink)
Stealth's Avatar
Shouldn't need to do that if he used his ebrake... I mean I've had it roll off on me if I didn't pull the ebrake but never without. And yes hydraulic jacks are awesome, definately get one and a pair of jackstands if you can afford it.
Old 04-10-2004, 01:22 AM   #11 (permalink)
The Twisted Brother
View Cam-Shaft's Photo Gallery
DOn't feel noobish...I had the same problem...but, I would just get a hydrolic jack.
Cam-Shaft is offline   Reply With Quote
Old 04-10-2004, 02:22 AM   #12 (permalink)
View Deep's Photo Gallery
Loosen (3 or so turns, don't take them off) the lugnuts on the wheel before you raise the car, there's less chance of having it fall and they're much easier to break loose on the ground. When you go to put it back on, tighten them as much as you can using your fingers, then fully tighten them when the car is on the ground.
When you're loosening or tightening the lugs, start at one nut, then move to the one furthest away, and then furthest from that one until you've done all 5.
Deep is offline   Reply With Quote
Old 04-10-2004, 08:40 AM   #13 (permalink)
Erbe's Avatar
k....i dont think its gonna get done this weekend anyway....i got work and dont got time.....ill jus do it with my dad next weekend
-pat
Old 04-10-2004, 10:20 AM   #14 (permalink)
Sold out for a Max
TheMajesticking's Avatar
View TheMajesticking's Photo Gallery
Factory Jacks.
-Chris
TheMajesticking is offline   Reply With Quote
Old 04-10-2004, 11:11 AM   #15 (permalink)
getn groceries in style
jwa276's Avatar
View jwa276's Photo Gallery
bingo. use your farken E-BRAKE! if you put the car in park/ in gear, it only locks the front wheels... meaning if you raise the car off the front, its going to be able to roll at free will!
toyota jacks work fine! just be smarter than the jack j/k
jon
'92 Camry SE V6 5spd
jwa276 is offline   Reply With Quote
