Originally posted by Zoni_Camry
do you know if there is a difference between 4cyl and 6cyl rear discs? or if the hubs are different? like... are the axles different like the fronts are or no? cause i was thinking of just throwing a hole wheel hub on...
On Gen 4 at least the v6 and i4 hubs and axels in the rear seem to be the same - I had no problems putting the disk brakes from a '00 v6 on my '00 i4... I don't think if in the US i4 gen4 Camrys come with rear disks at any trim. "Throwing a whole wheel hub on" is probably the easier option, although I chose to keep my old one and just replace the backing plate and everything else...
The front, some i4s have smaller disks than the v6, some have the same.
