Rear Wheel Play
My back driver side wheel can be wiggled side to side and you can here a clunk as it moves about 1mm.. a very small amount... now it has been like this for 80,000KM but I never did anything about it.. interestingly enough I can not feel or hear anything inside the car and the tire seems to wear evenly... but I can’t see how that even happens
So when I pull on the tire from side to side (towards myself gripping the tire on each side) it will wiggle 1mm side to side you and hear and feel it... the DRUM break cover also does this.. is that what the problem is or is it the bearing? (but I don’t hear a noise from it)... Oh and it is not a problem with a spacer that my mag needs.. the spacer is in there and looks just like the other 3
Thanks!
