Swaybar vs. Strut tower brace bar? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-11-2004, 06:11 PM   #1 (permalink)
View kenratboy's Photo Gallery
Question Swaybar vs. Strut tower brace bar?
OK, I am getting really confused.
For my Camry, I know I want new springs and struts. Fine.
However, people also said to get the Whiteline swaybars from CT Motorsport. I thought swaybars were the same as strut tower brace bars - they obviously are not.
What do I want? Do I want front and rear swaybars, or an I looking for strut tower brace bars, or both?
Thanks. I am getting confused.
At $250 for both front and rear sway bars, I want to make sure they are worth it - what do they do, and do I want them?
1997 Camry CE V6 5-speed!
Mods: Whiteline rear sway bar & nice tires.
2009 RAV4 Limited V6 4WD
Mods: nothing you would care about.
kenratboy is offline   Reply With Quote
Old 04-11-2004, 06:35 PM   #2 (permalink)
The Greatest
View CamNub's Photo Gallery
A strut tower brace bar i think goes inside under ur hood, while a sway bar is under the car. A sway bar will stop body roll (when your turning you wont lean into the door) a strut tower bar will stiffen the suspension. Correct me if im wrong you guys, but i think im correct on this one.
CamNub is offline   Reply With Quote
Old 04-11-2004, 06:38 PM   #3 (permalink)
Toyota Lover
KerTiZ's Avatar
View KerTiZ's Photo Gallery
anyone have a pic of where a sway bar under the car would go? >_<
i'm still a lil confused myself
KerTiZ is offline   Reply With Quote
Old 04-11-2004, 07:27 PM   #4 (permalink)
View Kling's Photo Gallery
http://www.stealthtdi.com/SwayBars.html
my friend sent me this link, it explains what a sway bar does and it's pros and cons, hope this helps
Kling is offline   Reply With Quote
Old 04-11-2004, 07:36 PM   #5 (permalink)
View gcs118's Photo Gallery
$250 for front and rear sway bar set sounds like a good price. You will notice more of a performance difference with the sway bars as opposed to the strut tower bar. Not sure if there are any, but upgraded end links may also be a good idea if thickening the sway bars, plus extra adjustability is always nice.
gcs118 is offline   Reply With Quote
Old 04-11-2004, 07:39 PM   #6 (permalink)
The Greatest
a strut tower bar is cheap too. I think you could get one 20-30$ used.
Old 04-11-2004, 07:40 PM   #7 (permalink)
I am looking at the Whiteline sways from CT Motorsport.
Are they 'radical' as in screwing up the drivability, or are they nice for someone who likes to attack the corners?
Thanks!
Old 04-11-2004, 07:41 PM   #8 (permalink)
View LebaneseCam's Photo Gallery
i got a strut bar, doesn't do very much, looks good though. The sway bar on the other hand, makes the cornering 10x better but its located under the car connecting to endlinks which r connected to struts. Worth it if installation isnt hard for you, i would buy it but broken and rusty bolts threatens my installation so i dont bother. Good investment i would think.
1993 Toyota Camry V6 LE.
LebaneseCam is offline   Reply With Quote
Old 04-11-2004, 09:49 PM   #9 (permalink)
3rd 5-speed Camry...
87Camry5Speed's Avatar
View 87Camry5Speed's Photo Gallery
Yeah...
If you have a good strut tower brace, say a TRD one, you're golden. It ties the front end together at the strut towers, making for what should theoretically be a stiffer front end. Most are for show, however, and flex with the shock towers like most all the Ebay ones (I have one of them)
If you want a practical upgrade and have the $$, go for the swaybars with some good bushings. It'll do WAY more for you.
Steve
'08 Camry LE 5-speed. Traded for an '04 Mustang GT.
87Camry5Speed is offline   Reply With Quote
Old 04-12-2004, 08:38 AM   #10 (permalink)
View BigAirSkier1580's Photo Gallery
A straight strut tower brace might cause the car to understeer more, but it will decrease the body roll some, which i have found to allow me to take the corners harder just because the car is a little more planted.
I guess the whiteline RSB AND a front strut bar is where your money is.
BigAirSkier1580 is offline   Reply With Quote
Old 04-12-2004, 12:23 PM   #11 (permalink)
View dj14901's Photo Gallery
If you had to choose between the two, I'd go with the front sway bar, it'll do a lot more for you than the strut tower brace. The front sway bar will fit in the same place as the factory front sway bar, if you have the front of the car jacked up (and properly supported), you'll be able to crawl under and see what I'm talking about.
HTH -
DJ
dj14901 is offline   Reply With Quote
Old 04-12-2004, 12:34 PM   #12 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700165
iTrader Score: 6 reviews
View EKam's Photo Gallery
You're contradicting yourself.
Understeer means the car is losing front traction, if your car is little more planted that means you're getting reduced understeer.
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 04-12-2004, 01:13 PM   #13 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
FWD cars already understeer as is, so upgrading the front sway bar will just give you more understeer.
I would go with a rear sway bar and strut tower brace.
"Skoolin' the unlearned!"
Old 04-12-2004, 06:10 PM   #14 (permalink)
eeto........?
View _VVTi_'s Photo Gallery
isn't front sway bar and tower bar the same??
1994 Camry LE V6
Tokico blues + Vogtland / Depo headlamps / Clear bumper light / Silverstar / AEM CAI / Tenzo R Formula 10 + Kumho 215/50/17
_VVTi_ is offline   Reply With Quote
Old 04-12-2004, 06:23 PM   #15 (permalink)
How? And if that was the case, why would anyone buy a $120 tube as a preformance part to make a 'bad' thing worse?
So I shouldn't do a front sway bar then? What about a rear?
