How much HP can it handle? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-08-2002, 06:19 PM   #1 (permalink)
View LboWookiee's Photo Gallery
does anyone know how much horsepower the stock tranny from a 1996 manual 5sfe camry can handle? I'm looking to swap a 3sgte into it and I wanna know how much i can build up the motor with that tranny arrangement without dropping it out onto the highway. Thanks guys
1996 camry coupe 5spd
LboWookiee is offline   Reply With Quote
Old 04-09-2002, 11:45 AM   #2 (permalink)
9thGen Corolla
karma's Avatar
View karma's Photo Gallery
depending on if u build it or not a 5sfe can handle upwards of 500 crank hp if built properly or as low 150 crank hp if not, all depends on how it how its built, u have to spend money to play with the camry, its not a honda so by no means are there n e real parts available, just about everythings is gonna be custom fitted and cost an arm and a leg
karma is offline   Reply With Quote
Old 04-09-2002, 03:28 PM   #3 (permalink)
That's helpful, but I was really wondering about the tranny itself, cause I was planning on reusing it for a motor swap and I don't wanna drop the tranny on the pavement the first time I romp on the gas...
Old 04-09-2002, 04:10 PM   #4 (permalink)
9thGen Corolla
karma's Avatar
auto tranny starts giving on the 4cyl above 200 hp, the manual is supposed to be good for up to 500 if u know how to drive it and don't smack the gears around like your on crack and driving a honda hehe j/k but thats what i've seen
Old 04-09-2002, 05:05 PM   #5 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
Karma is correct on the 5S-FE 5 speed tranny handle almost 500hp at the crank... I would suggest act 6 puck clutch and granny shifting... I wouldnt suggest 3000rpm drops for the tranny , unless you want to see what your 5speed tranny looks like from the inside...
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 04-10-2002, 12:42 PM   #6 (permalink)
9thGen Corolla
karma's Avatar
[/quote]
[/quote]
lol yeah and everyone else on the street seeing it either
Old 04-10-2002, 04:58 PM   #7 (permalink)
so what you guys are saying is that in gear it'll handle around 500hp, but if i try to launch the car pretty good, then It'll hit the pavement with a serious thud, Right?
Old 04-10-2002, 11:35 PM   #8 (permalink)
View mndthrshr's Photo Gallery
why the radical difference between auto tranny and manual? i was hoping to keep my auto when either turboing my 5S-FE or doing a engine swap. how can you beef up a auto tranny?
Be careful guys. He may be running a stage 2 enhanced sticker kit!!!!
mndthrshr is offline   Reply With Quote
Old 04-11-2002, 01:13 AM   #9 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
nope just you would have to feather the clutch off the line ... but you'll need to upgrade the clutch and have the tranny over hauled for the insurance...
MySpace:
Old 04-11-2002, 01:19 AM   #10 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
if you do a engine swap and want to keep your automatic theres 3 ways of doing it.. 1) running a 3S-FE and tune it for turbocharging duties, modify the fuel and ignition maps...2) running an late model J-spec. 3S-GE automatic ecu and tune the ecu for turbocharging, modify the fuel and ignition maps... 3) stand alone...
as for re-enforcing the automatic tranny you could try to give Level 10 ( if they're still in business) or Sound Performance in Chicago... But be ready to spend between $5000 to $7000 ( turst me I've already researched this)...
MySpace:
Old 04-11-2002, 10:53 AM   #11 (permalink)
9thGen Corolla
karma's Avatar
the auto tranny will hold fine on the turbo fo a while, mines was holding up and i was boosting more than what the burien kit does. i suggest tho some source of cooling for it, via tranny cooler, and don't get boost happy or u will end up blowing fluid out everywhere, i mean yeah u can boost and race everyonce in a while but don't go on no hour racing spree where your racing everyone and their mom in like 100 degree weather, if so your asking for trouble
